OME Front Suspension Install Help
Attempting to install an OME suspension in my 98 4Runner but having tremendous trouble compressing the front coil spring with coil spring compression tools and still having room to fit the spring/shock while compressed. Any help regarding compressing the spring/installing spring/shock in front?
Keep compressing...you may want to disconnect the ball joint that links the top of the spindle to the upper control arm and jack that part of the setup down to get more clearance. other than that(sorry, 4th gen cat here), just get tough with the sucker and send it into place. hope that helps.
anthony
Perhaps this might give you some insight...
http://www.drawhorn.org/front_ome_install_writeup.htm
So turn the damn lower cup the other way...
Originally Posted by waskillywabbit
Perhaps this might give you some insight on how to install the parts the wrong way...
Originally Posted by sschaefer3
That's a great write up on how to incorrectly install the lower cup.
I can always count on you for those late night spooning sessions, when's our engagement Steve!
Can't you two see that you're in love! have a good day, mike
Do you have the coil-shock assembled? Is it all ready to be installed in to the truck?
If so, the best method is used above. Take your bottle jack and put it upsidown on the upper a-arm and the inside wheel well. Screw it till it is pushing down the A-arm at a pretty good angle. Make sure that its secure though, because I had it pop out on me!
Best thing to do is put it far down so you can install the newly assembled strut...hand tighten the top three bolts, and then ajust the jack up/down until you can look through the bottom eyelet mount and stick that big bolt back through.
You know that you have to take the coil spring compressors off before installing, right?
Sep 4, 2015 09:27 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
Vargntucson
Jul 4, 2015 12:15 PM
4runner, 98, coil, emu, front, install, installation, installing, kit, man, ome, springs, strut, suspension, tacoma
