Removing ADD System on 7.5 Diff??????
Old Oct 11, 2004 | 08:10 PM
Can anybody tell me how to remove the long side of a 7.5 diff on an 88 and put it on a 91 to eliminate the ADD locking mech. I've been told you can do it and seen pics but don't know how to get the axle out of the pumpkin. Thanks for your time............ TIM
Old Oct 11, 2004 | 08:22 PM
Glenn's Avatar
On mine, there were several star shaped bolts to remove. I had to get some special sockets to fit. It is fairly straight forward.
Old Oct 12, 2004 | 01:01 PM
Robinhood150's Avatar
Here's another way of doing defeating the ADD. http://www.4x4wire.com/toyota/tech/add/
Old Oct 12, 2004 | 08:42 PM
95_4X4Runner's Avatar
I used the method above to disable my ADD after I had the 83' Supra LSD Diff installed. Basically, pull the cover off, lock the ADD, and put a hose clamp in there to prevent it from coming unlocked. I just capped off the vacuum hoses, haven't had time to remove all the stuff.
Old Oct 12, 2004 | 09:40 PM
Thanks guys, once again yotatech has come through to get me back on the road and in 4WD.......... many thanks!!!!!
Old Oct 12, 2004 | 10:17 PM
Brendan's Avatar
all i did is slap on the manual hubs and everything seems to work fine. what am i missing?
Old Oct 13, 2004 | 12:53 PM
Flamedx4's Avatar
There really isn't any need to remove the ADD, the things aren't prone to failure. But if you want to, just unbolt the ADD clutch case and short axle tube from the diff case, and replace them with a long axle tube from a non-ADD truck, or so I've been told. I *think* the original axle ("side gear shaft") is good to go too, but you might double check on that.
Old Oct 13, 2004 | 12:56 PM
Flamedx4's Avatar
And don't forget to remove the vacuum mechanism (just to be neat) and to tie the two wires together for the switch on the ADD mechanism so your 4x4 light still works.
jerusry
Oct 19, 2015 05:28 PM
jaretstuff
Aug 4, 2015 02:08 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
rushw
Jul 18, 2015 01:46 PM
