2nd Gen 4runner suspension questions...
ok, I've been researching this for a while because I'm on a nickels and dimes budget and just looking for a lift to put on my 2nd gen 2wd that is basically just a pavement pounder, and I have a few questions I'd like to ask the experts.
1. Is there any body lift options for automatic transmission 2nd gens?
2. Does anyone supply a cheap complete lift kit just for the front?
I'm looking for around 5 inches of lift somehow as cheap as possible. I know there are 5.5 inch lift coils for the rear, and I was looking for a cheap 4 inch kit for the front and 1.5 inch ball joint spacers.
thanks for any info available, thanks.
Roger Brown makes a lift kit for the auto trans 4runner.
the best kit out there to.
I belive the link is www.4crawler.com
Why do you want a 5" lift on a 2WD 4Runner?
If you want to run 33's, you don't need much other than the 1" BL, some rear leveling springs (Downey, OME, etc.) and a slight tweak of the torsion bars.
Want more (but cheap), add a 1 1/2" ball joint spacer up front and Land Cruiser rear coils and work the wheelwells a bit, close to factory backspacing on the wheels and you can probably fit 35's.
A local shop has the OME's, I wanted the downeys but can't seem to find anywhere to buy them. Does anyone know of a good mailorder source?
Also, where would I be able to get landcruiser springs? and I would I have to do any kind of mods to put them in?
I don't want to have to grind any skid plates or worry about drive line angles, so should I just stick with the 1.5"?
Jun 1, 2021 01:51 PM
Steezy96yota
Jul 6, 2015 10:00 AM
