driveshaft center bearing went out, i think. please help.
Old Sep 21, 2004 | 11:01 AM
wimpywade94's Avatar
ok, so my driveshafts center bearing thing went out i believe, the driveshafts vibrates EXTREMELY bad driving down the road, and when you push up on the drive shaft it has quite a bit of play in it around that center point there, how hard is this to replace and how much am i looking at spending? is it rebuildiable and is there something that caused this to go out,
is there anything im overlooking here? like mabey it was something else that went out and it ruined that to or mabey that something else is wrong with it and i just think its the center bearing.
thanks for the help
wade
Old Sep 21, 2004 | 12:55 PM
EWAYota's Avatar
this on the tacoma or the older toyota?
Old Sep 21, 2004 | 01:32 PM
toy283's Avatar
The bearing ain't cheap. I replaced two of them at $180-200 (for just the part) before I went one-piece and never looked back. Not sure if that's an option in your case as I don't know what truck you have.
Old Sep 21, 2004 | 01:46 PM
its in the taco,
how would i put in a one piece;.
later
wade
Old Sep 22, 2004 | 07:08 PM
Hyperlite's Avatar
change the u-joints in the double cardigan and see if that works
Old Sep 22, 2004 | 09:00 PM
actually i just got home from being stranded in town, it was the rear u joint, when i looked at it, it was somewhat cocked and still felt like it was tight, but was really just jammed up, and that was causing the center bearing to look like it was bad for some reason, then today when i was driving it started making a horrific shaking and noise so i pulled over and looked and sure enough it was the rear joint, got a new one, started to press it on, and the cap exploded on one side so i couldnt go no further, i tried everything, but have boiled down to i have to cut it out, and repair the entire rear joing carrier thing, it sucks let me tell ya what.
oh well, i should have it finshed tommorw.
pos.
wade
Old Sep 22, 2004 | 09:02 PM
EWAYota's Avatar
u got to quit beating up on that rig if your gonna sell it!
Old Sep 22, 2004 | 09:04 PM
hey,
you zip it!!!
insurance is gonna cut me a check for damages next week.
besides, why do you think that i didnt run it in the mud bogs?
oh well,
you want it? ill give you a hell of a deal
wade
Old Sep 22, 2004 | 09:06 PM
EWAYota's Avatar
no i dont want it! its a beat up and breakin on ya! i figured you didn't run it in the bogs because everyone there with a mildly modified truck didn't make it past 10 feet! why do you think i didn't enter my truck!!!
Old Sep 22, 2004 | 09:11 PM
because your a wimp.
wade
Old Sep 22, 2004 | 09:21 PM
EWAYota's Avatar
wade
i didnt want to cough up the 20 bucks to get the front tires muddy and not make it any further!!!!
they did the pit backwards, it should have started off shallow, and let all the stock and mildly modded trucks dig it deeper for the higher more modified trucks. heck, when levi's rig only made it thru 1 side on 44's, while we were still in the stock class, theres a clue right there!
don't get me wrong, i had a blast watching the trucks get stuck, and you ALMOST get stuck, but the design wasn't the best.
glowz825
Jan 25, 2022 09:28 AM
Tonetrk
Aug 6, 2015 10:06 AM
Up&Down
Aug 5, 2015 06:20 AM
coffey50
Jul 28, 2015 10:55 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
