Front rotor installation
Old Dec 7, 2002 | 04:26 PM
oly884's Avatar
Guest
I'm going to get some new front rotors from NWOR. My question is, is it hard to change the front rotors. I can do most things, brake pads, belts, fluid changes, all that kind of stuff. If it isn't too hard, what tools will I need? Any info will help.
Old Dec 7, 2002 | 05:58 PM
Robinhood150's Avatar
What year truck and is it 4x4 or 2wd?
Steve
Old Dec 7, 2002 | 06:04 PM
sherri_girl's Avatar
try this:
http://www.4x4wire.com/toyota/mainte...ont_end/rotor/
http://www.4x4wire.com/toyota/mainte...nd/reassembly/
Old Dec 7, 2002 | 06:31 PM
oly884's Avatar
Guest
i have a 90 4x4 with the v-6
Old Dec 7, 2002 | 07:04 PM
williemon's Avatar
Use a torque wrench on them, be gentle, and make sure you have the big socket for the bearing nuts. I assume you will repack the bearings too. Check out those links sherri posted. Lots of help.
Old Dec 8, 2002 | 06:21 PM
Toby1's Avatar
Might also want to check the front axle seals and make sure you're not leaking grease.
Old Dec 12, 2002 | 09:06 AM
jx94148's Avatar
I think by this you mean CV boots. If any of your CV boots are leaking now is the time to replace them, while you have the hub torn down. You do not need to remove the CV axleshafts to change rotors if you arent replacing the boots. You need a 54 mm socket or 2and 1/8th inch socket to get the knuckle off of the spindle. Also I reccomend a new hub face gasket to keep it watertight. At the very least use black RTV gasket sealer to seal it tight.
Old Dec 12, 2002 | 12:14 PM
oly884's Avatar
Guest
Thanks for all the info. I'll probably be changing them within the next month.
If things get confusing then i'll be back
kazuya2416
Apr 5, 2024 02:17 AM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
msane99
Jul 11, 2015 08:08 PM
crashburnoveride
Jul 10, 2015 06:39 AM
