T-stat help fast!!!!!!!
i went to autozone to buy a t-stat. they asked which one medium or high temp. what the difference??? i asked for the medium cuz its said OEM model underneath. should i have gone with the high?
i need to have this done buy tonite...so i can go to work tomarrow
You might want to replace your fan clutch if it's overheating on the freeways. Not positive but , your old one was a 195*, and the new one is 180*F. If that doesn't solve your problem then it might be the fan clutch or a radiator going bad.
Perhaps a radiator flush might loosen up some debris. The worst situation is water pump failure.
Cheap fix ... radiator flush ... Jiffy lube or oil can henry's is about $100
Expensive fix water pump ... $300 and up for parts and labor
Longbed 90
Mar 11, 2019 12:38 PM
Scotttekoch
Sep 28, 2015 10:30 PM
