T-stat help fast!!!!!!!
Old Aug 3, 2004 | 06:17 PM
Tokez420's Avatar
i went to autozone to buy a t-stat. they asked which one medium or high temp. what the difference??? i asked for the medium cuz its said OEM model underneath. should i have gone with the high?
i need to have this done buy tonite...so i can go to work tomarrow
Old Aug 3, 2004 | 06:38 PM
Tokez420's Avatar
the truck is overheating only on the freeway. i just took out the old t-stat and it says its a 88°c and the new is 82°c.
Old Aug 3, 2004 | 06:43 PM
rimpainter.com's Avatar
Sounds good. Your MPG might drop a touch, but that's it.
Old Aug 3, 2004 | 06:48 PM
86toyota's Avatar
You might want to replace your fan clutch if it's overheating on the freeways. Not positive but , your old one was a 195*, and the new one is 180*F. If that doesn't solve your problem then it might be the fan clutch or a radiator going bad.
Old Aug 3, 2004 | 07:07 PM
Tokez420's Avatar
yea i already replaced the clutch fan. it did help a lil.
Old Aug 3, 2004 | 08:46 PM
amusement's Avatar
Perhaps a radiator flush might loosen up some debris. The worst situation is water pump failure.
Cheap fix ... radiator flush ... Jiffy lube or oil can henry's is about $100
Expensive fix water pump ... $300 and up for parts and labor
Old Aug 3, 2004 | 08:54 PM
Tokez420's Avatar
new water pump.....if this doesnt work i guess it gunna be the radiator
Old Aug 4, 2004 | 04:27 AM
Yoda's Avatar
Sounds like radiator to me. Its not plugged with mud or stuff that prevents air flow through it??
Old Aug 4, 2004 | 04:54 AM
If the water pump was toast, you would have coolant leaking from the weep hole. Not a lot, but enough to notice.
Longbed 90
Mar 11, 2019 12:38 PM
puddlepirate
Jul 30, 2016 06:29 PM
Scotttekoch
Sep 28, 2015 10:30 PM
Project90
Sep 24, 2015 11:40 PM
bhaithc
Sep 17, 2015 07:53 PM
