land cruser axle into a 1st gen 4runner ???
Old May 9, 2004 | 10:17 PM
slickrock's Avatar
Does anyone know if a toyota axle out of a 77 land cruser will be ok for a sas in to a 88 4runner. What are the difrences between it and a up to 85 truck solid front axle. and help would be great.
Old May 10, 2004 | 03:53 PM
Fahrenheit 451's Avatar
If I remember correctly, there is a difference in the spring perches and knuckle set ups since the Landcruiser axle is spring under and the SAS requires a spring over setup. To properly do a springover lift on the Landcruiser, the axle housing has to be cut and rotated in order to get the correct caster angles.
Here is a page with some info on it:
http://www.off-road.com/toyota/tech/...r/index1b.html
Old May 10, 2004 | 04:14 PM
Flygtenstein's Avatar
Width should be right on.
Perches, even if they were the right width would be under as was mentioned.
You get a bigger ring and pinion, but you can't swing a high pinion like with a 79 to 85 housing.
Tough call.
Old May 10, 2004 | 05:45 PM
sschaefer3's Avatar
You'll have to switch it from a spring under to a spring over when typically means sending the houseing off to be cut turned.
The LC diff is 9". That's a big sukka.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Jul 6, 2015 04:07 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
