Rear OME lift going in today ... dump questions (help)
Old May 8, 2004 | 06:01 AM
shazaam's Avatar
you think I would learn and just pay someone else to do these things. But nope, I'm a gluten for punishment. I'm getting ready to put the rear OME set up in today.
first question .. the rear sway bar ... is that the solid bar that runs right behind the rear axle.
I already have a couple of write ups .. so I'll keep posting questions as I go along, and if you guys have nothing better to do this saterday morning, you can get a good kick out of me putting this in
thanks
Old May 8, 2004 | 06:08 AM
runnerboy97's Avatar
nope, the sway bar is the curvy on the attaches to the frameby the wheels. you can see the endlinks with the wheels on if you look into the wheel wells. you are thinking of the panhard bar, that locates the axle side to side. All you have to do to put in the OME is undo the swaybar, undo the shocks, and the axle should droop enough to work the old springs out, and put the new ones in. Be careful and good luck.
Old May 8, 2004 | 06:17 AM
shazaam's Avatar
thanks ..
also do I have to pull both sides out at the same time . or can I do one side, put the tire back on and go do the other side?
Old May 8, 2004 | 06:20 AM
shazaam's Avatar
ok I see the curved bar, its the one lllying right on top of the frame, .. where do I disconnect it at?
Old May 8, 2004 | 06:31 AM
Albuquerque Jim's Avatar
If you have the wheel off, there is a connector link (almost just like the front) just in front of the wheel inside the wheel well. All you have to do is take the nut off of the top and remove the washer and bushing, you don't have to take the link off of the swaybar.
Old May 8, 2004 | 06:40 AM
Mad Chemist's Avatar
The worst part about the rear is getting the top shock nut off. If you haven't already, using strap wrench on the shock body worked pretty well for me. Good luck!!! Make sure you install the taller spring on the driver's side, as my OME springs were mislabled.
Old May 8, 2004 | 06:57 AM
shazaam's Avatar
bottom nut on the shock is off, and the sway bar is diconnected. I need to go get a vise grip for the shock, I can't hold it with on hand, and twist with the other.
off to sears I go
Old May 8, 2004 | 08:11 AM
shazaam's Avatar
hey the OME shock has a metal wire wrapped around it .. I take that off right?
Old May 8, 2004 | 08:16 AM
AZ4ME's Avatar
Yes, that wire keeps the shocks compressed during shipment.
Old May 8, 2004 | 09:00 AM
waskillywabbit's Avatar
Talking Rear sway bar
This is it in the picture, just disconnect it at the top and let the sway bar sag down.
Good luck!
Old May 8, 2004 | 09:10 AM
shazaam's Avatar
one side is done ...gotta go throw some mulch now .. will try to do the other side tonight.
Old May 8, 2004 | 11:49 AM
shazaam's Avatar
I'm done
Old May 8, 2004 | 11:57 AM
MTL_4runner's Avatar
I'm done
Let's see some
Old May 8, 2004 | 12:38 PM
Scofco's Avatar
Congrats mate
I actually came on here to see how it went.
Old May 8, 2004 | 01:27 PM
shazaam's Avatar
it makes the front end look really low.
It was level with the spacers and the OEM shocks and springs. But with the new set up, its angled forward like a racecar. I thought that 150 lb bumper on the rear would bring it down. bu
will get a pic up in a few minutes
Old May 8, 2004 | 01:48 PM
shazaam's Avatar
Old May 8, 2004 | 01:49 PM
shazaam's Avatar
Old May 8, 2004 | 02:00 PM
Scofco's Avatar
Your truck looks like mine now
How do you plan on leveling it?
Old May 8, 2004 | 02:02 PM
shazaam's Avatar
Crank the SAWs up some, and add the diff drop sitting on the shelf.
Old May 8, 2004 | 02:06 PM
Scofco's Avatar
I'm slowly cranking mine front when I have time, it's a pain in the butt.
My passenger side is sitting about a half inch higher than the drivers side right now.
Still have about 3 inches total of cranking to go, it's a slow process.
