88 4Runner 3.0 water bypass question
Old Mar 23, 2025 | 08:43 AM
LGslo's Avatar
Hey guys, I'm hoping to get some clarity on the sensors in the water bypass block on my 88 4Runner 3.0 AT. I think I have most identified, but I'm unsure of what the red arrow is. Possibly a coolant temp switch that activates overdrive? Any help or adjustments to what I have labeled is greatly appreciated. I found the water bypass was mostly clogged, which could explain why my OD is intermittent and why I have a hard start and low idle at times. I also can't pass smog so I'm rebuilding the fuel injectors as they are likely contributing to high HC. Lots of stuff going on.
Old Mar 23, 2025 | 02:09 PM
LGslo's Avatar
Update: I think I got it all correct with lots of digging. Hopefully this helps someone out there down the road.
Old Mar 26, 2025 | 03:05 AM
PaigeGriffin's Avatar
Thank you.
Spoiler
LGslo
Sep 25, 2024 03:53 PM
jagermeister
Aug 31, 2022 07:21 PM
WartHoggRunner
Dec 8, 2012 08:02 AM
jim628
25
May 18, 2007 02:58 PM
Ava
Aug 24, 2003 04:56 PM
