T731 Distributor doesn't match size of OEM
Old Feb 22, 2025 | 02:58 PM
prcnctoyo's Avatar
I purchased the distributor on the left from RockAuto. It was listed as Famous Brand T731. It came in a Carquest box. It's diameter (67.5mm) is smaller than an old OEM (pictured on the right) and aftermarket distributor (77 mm) I'm currently running.
I went to a local Advance Auto that use to be a Carquest location, that I've been shopping at for years, to see if they could tell me what distributor cap to order for future reference. All of the caps in their system for my 22R is the size that fits the OEM. They ordered in a T731 to see if what shipped from RockAuto wasn't the correct part. It was the same. Advance Auto online says a T731 will fit my '87 22R. The EFI distributor is listed as a T755. When you try to pull up the T755 on Advance Auto online, it displays the T731.
I'm wondering if this is a distributor for EFI? Anyone have any ideas? I can't use if if I don't know what cap/rotor to order in the future. Would my timing be different if I used this one? I've thought it might be worth keeping just for the advance.
Carquest T731 on left, old OEM on right
Old Feb 22, 2025 | 07:38 PM
millball's Avatar
22RE (EFI) distributor does not use vacuum advance
Pri$erulz
Dec 16, 2018 12:54 PM
arlindsay1992
Feb 21, 2017 01:11 PM
ChinkTruck
Dec 22, 2016 07:24 AM
mpdxtreme
Dec 12, 2014 08:10 PM
Dylan86
Sep 4, 2013 07:08 AM
