1994 pickup 2wd. No possible history.
Old Jan 25, 2022 | 02:06 PM
adeiyadad's Avatar
1st manual Car. Couldn't get a better version due to money wise. I don't make that much. So fixing some stuff and tuning the truck has been an issue. I got it for cheap and I'm learning everything about it as I go. I believe this is W56 transmission there's a plug that's connected that's leaking fluid. Is it the transmission fluid? It seems black. I ordered a fill plug and drain plug with washers. Just incase if it's done for so I can just replace it when I drain it. But if anybody has any idea what should I do with that plug on the left that's covered in oil. Every help is appreciated. Whatever worked. This is gonna be my daily driver. It is right now . Let me absorb all of yous knowledge. Thank you again
Old Jan 25, 2022 | 04:35 PM
superex87's Avatar
That appears to be the back up light switch. Tunes on the backing up lights when you put the transmission in reverse. Easy to replace and it should have a crush washed under it that seals it off.
musician235
Jul 14, 2021 11:36 AM
wykp
Mar 17, 2021 01:51 PM
Cesar Telles
Feb 12, 2019 09:06 AM
tarra.dactyl
9
Apr 20, 2017 10:21 AM
rowdy235
May 19, 2008 08:34 PM
