89 4Runner Tailgate Tensioner Rattles
Old Jan 11, 2022 | 04:40 PM
68jimmy's Avatar
Good evening,
I'm not sure what they're name is but I'm referring to the two L shaped rods that fit under and into the tailgate that provide tension to assist when lowering... Anyway, when driving they are free-floating and rattle quite a bit over bumpy terrain. Is there any fix to reduce/eliminate the rattle?
Thanks in advance
donovan
Old Jan 12, 2022 | 11:22 AM
Blueman's Avatar
Are you sure that's where your rattle is coming from? I ask because I've found the two hanger straps on either side of the tailgate to rattle when their little plastic anti-rattle brackets break -- I'd check those first.
As far as I can recall, those torsion springs under the tailgate to lighten the load are under tension at all times on my '87.
Here's a part # for the anti-rattle plastic parts that go on the sides of the tailgate opening to keep the hinged straps from rattling.
Old Jan 12, 2022 | 11:56 AM
wallytoo's Avatar
there are four of the anti-rattle clips used. 1 at each side on the body opening and one at each side on the tailgate.
Old Jan 12, 2022 | 03:09 PM
68jimmy's Avatar
Thanks Blueman. I'll certainly order a set of those as both of mine are broken. However, after taking time yesterday to narrow down where the rattle was coming from I wrapped the tailgate hangers with pieces of inner-tube, and tightened a few screws in the tailgate inner cover. It was while I had the inner cover off to lube the rear window regulator and with the tailgate closed I was able to reach in and move the right torsion spring back and forth. Which is what I'm hearing when driving. I didn't check the left...
Thanks
Old Jan 12, 2022 | 03:10 PM
68jimmy's Avatar
Thanks wallytoo.
Old Jan 12, 2022 | 04:00 PM
wallytoo's Avatar
the tension springs/rods pass into the tailgate via a plastic grommet. perhaps the grommets are missing?
Old Jan 12, 2022 | 07:22 PM
68jimmy's Avatar
That's probably the case... I'll take another look and see one or both are missing.
Thanks.
2003mikem
Aug 9, 2011 05:10 AM
mardo87
Oct 23, 2008 10:14 AM
dirtykaw
Jan 6, 2008 11:12 AM
tombothetominator
Jul 18, 2006 08:45 AM
Los Gatos?
May 12, 2003 07:16 AM
