I have spent many days trying to find the part numbers to these hoses. My local dealership is an hour away and currently I have the plenum off to replace injector o-rings and all the rubber I can see.
Primarily they are the heater hoses and the two hoses in the back driver side of the engine. Every diagram I can find only has the first half of the hose part numbers. Pictures attached. Also I included a picture of the coolant nipple that connects to the bypass hose that goes to the throttle body. I am also unable to find that part number.
I have a haynes manual but it has been rather useless. Anyone know if a toyota repair manual has part number diagrams?
Thanks 1992 toyota pickup Really need the bottom left hose to change while the plenum is off. Coolant nipple
Get the model number and production date off your vin plate. With that, looking up parts on EPC-Data or Amayama is fairly easy.
The images they use are very similar to the microfiche Toyota Parts Depts used bit
Once you get your model# put it in your signature. That way we can all see it and make it easier for us to help locate parts for you or answer questions
For OEM Toyota parts I go online to Conicelli Toyota. Seems to have the lowest prices compared to others online. My local doesn't carry any parts. They will answer any questions like part numbers, specs,....etc.
Replaced all the hoses, clamps, and injector seals and she is leak free. The old hoses were very stiff, bulging by the connections, cracking at the ends, and deteriorating inside where they connected. They were much worse than I thought from just looking at the outside of them.
Yep, that's my favorite free parts catalog website (I'm a Toyota parts guy...but those are the exact same diagrams that Toyota uses, and I've found them to be VIN accurate)
I've purchased from them, too. I really like that they will actually tell you if a part is manufacturer discontinued, and will show any supersessions. I use these 2 websites with every OEM part that I look up for myself.
