2000 toyota tacoma 3.4 water pump leak
My tacoma is leaking directly from under the thermostat housing in between the bolts. It isn’t coming from the bolts, i see exactly where it’s coming from. I just changed my water pump and timing belt. I also changed the gaskets and thermostat, now it’s leaking very quickly out of the water pump. I will open and take out everything again and see if the block is warped or cracked. I made sure to clean the mating surface for the gasket and made sure there was no old gasket or grease there. What could be the reason it’s leaking so fast?
customdrumfinishes
Oct 2, 2010 02:47 PM
Mike Murrell
Aug 4, 2010 04:56 PM
