E brake cable
Old Jul 10, 2021 | 03:16 PM
Pinion@@'s Avatar
E brake cable
Is it possible that ebrake cable is stretched beyond adjustment.just did rear brakes, (everything) and can’t get brakes to grab nicely. No more adjustment under cab, and yes I pulled drums against to make sure all was in right way
91 pickup ext cab 4wd 3.0 manual
thanks
Old Jul 12, 2021 | 10:39 AM
Jimkola's Avatar
YT Community Team
5 Year Member
If you mean the parking brake isn’t holding the vehicle when fully engaged I think you might need to make the adjustment at the bell crank. It’s about half way back, where the front cable is joined to the two rear cables. You might need to undo the adjustments you made at the drums, then tighten the adjustment at the bell crank. Then you can go back and fine tune the drum adjustment.
Old Jul 12, 2021 | 10:59 AM
Pinion@@'s Avatar
well attaboy didn’t adjust the rears enough
issue resolved
Rapidrob
Jan 13, 2016 04:42 PM
yotakid825
Jun 2, 2009 08:42 AM
jerbear
Nov 9, 2007 12:33 PM
bad_brains
Feb 13, 2007 06:08 AM
Etype R
Nov 14, 2005 06:37 AM
