2010 Tacoma Chirping Sound
Hello Everyone! I am having a rough time diagnosing a chirping problem with my 2010 Tacoma TRD Sport. If I pullout slowly it doesn't seem to be as bad, however, if I pull out fast it chirps then goes away.
I can't find any metal to metal contact or issues involving the transmission. It shifts gears smoothly and doesn't slip. Also, it doesn't appear to be a wheel bearing since the sound goes away after you reach 25ish mph.
Any help would be greatly appreciated!
Thank you!
Thank you!
Thank you!
Thank you!
Does it chirp when you apply the brakes?
Does it chirp when you turn the wheel to the stops?
Could it possibly be a U-joint? Crawl under and wiggle the drive shaft. Does it turn, or move in ANY axis when you do? Are there grease-zerts on the u-joints? Have you tried lubing them well if they do?
Have you checked the thickness of the rear brake shoes. The front pads?
Just throwing ideas out there. I get the so few and far between, I gotta get them out there, before they vanish on me.
Good luck to ya!
Pat☺
Good luck to ya!
Pat☺
darbtaco11
30
Jan 1, 2013 07:08 PM
Fink
Feb 4, 2010 04:38 PM
yamaboy03
Jan 29, 2010 02:03 PM
