Problem with 1987 AT
Old Feb 22, 2021 | 07:49 PM
Ratpin's Avatar
I have a 1987 4x4 pickup with 22re and automatic trans. Everything was operating normally. A couple days ago I removed my ECM to clean the area behind it. I reinstalled it today and now my transmission is not acting right. Reverse works fine as does low gear, but when I put it in drive or 2nd, it will not go to and start in the lowest gear. it will move, but it’s obviously not in first gear and barely inches forward with no power and will not downshift to the lower gears. Can anyone think of a reason why or have experience with this type of behavior? The fluid is clean and on level.
Old Feb 23, 2021 | 04:46 AM
87-4runner's Avatar
I'd sure be suspicious of the ECM connections, wiring... go back to what you did and check to see what changed?
Old Feb 23, 2021 | 06:52 AM
Ratpin's Avatar
ive gon back through a few times now and inspected all the wires plugs and pins. Disconnected, reconnected and it happens the same everytime. Really weird.
Old Feb 23, 2021 | 06:14 PM
Ratpin's Avatar
Bumping this up for the brain trust!
Old Feb 24, 2021 | 04:42 AM
87-4runner's Avatar
Check out the RELATED TOPICS right under my post ....
o/d relay?
Old Feb 24, 2021 | 04:43 AM
87-4runner's Avatar
o/d relay?
(1987 4runner Auto Trans acting crazy)
Old Feb 24, 2021 | 06:44 AM
Ratpin's Avatar
I saw that thread and just like the other guy responding, I don’t have that blue relay there. Instead I have a black box that says “OD” on it. I did try unplugging that and starting the truck. That did not have an affect in anything.
dbbowen
Dec 1, 2015 05:58 AM
Carvey1989
May 18, 2014 10:31 PM
WhiteWulf
Feb 18, 2008 06:23 PM
