brake/tail/reverse lights off ecu or switch?
Old Jan 2, 2021 | 10:10 PM
19874skinner's Avatar
hello everybody, i am trying to rewire a 1987 4runner that had the whole rear wire harness removed from dash back...am i wrong to assume that i can run wires straight from the brake pedal switch to a fuse, and then straight to the rear brake light? As for reverse, is it normal to have the light controlled by a wire from the ecu, or again just straight from the wire coming off the shifter (aftermarket floor shifter so has a single wire coming off a switch that is triggered when in reverse) For tail lights, is it normal to just tap off a fuse that is always powered when driving, fuel pump or ignition or something of that nature? Again should that be triggered by something from the ecu as well?
Will the small lights in the rear be too much for these switches, should they all run a relay between each? is it better if i used led bulbs, or is that just putting a bandaid on the problem?
fuel pump and everything needed to run offroad are wired up, and done fairly well...just would like to drive it on the road a bit more
Old Jan 3, 2021 | 02:35 PM
irab88's Avatar
tail is on a relay controlled by the combination switch, brakes and reverse directly off of switches mounted on the pedal and transmission, respectively.
no ecu for any of them
Old Jan 4, 2021 | 12:09 AM
RAD4Runner's Avatar
Like Irab Says ^^^
1987 should be close to, if not same as, 1988...
19874skinner
9
Jan 8, 2021 07:12 PM
david braun
Jan 10, 2013 10:50 PM
sixt5
Oct 2, 2008 11:13 AM
nomiss05
20
Aug 4, 2008 03:15 PM
FlipSide
Mar 5, 2004 09:31 AM
