Not sure how this got like this, looks like the inlet side got dented in and pushed a little crooked.. it isn't leaking or anything but would this effect its performance much or should I not worry?
Looks like the fuel filter I changed out last year, though the opposite end is bent. As far as I know it was still functioning, I decided to swap it out when my fuel pump failed, just for piece of mind.
since it’s already out, and you need to replace the crush washers, why not replace the filter?
Cost. Plus I don't/didn't want to have to wait for a Wix or OEM one to ship. This covid crap is putting a strain on both of those unfortunately, otherwise I would normally replace it for sure. I'll anneal the washers if I don't get replacements.
Weird!! Are you sure it wasn't your fuel filter that was the culprit? Maybe it was backwards (pretty sure they are supposed to be installed 'backwards' from a visual perspective) and causing the fuel issue and something is pressing our filters in on the inlet side? Not questioning your intelligence or mechanical ability, just a thought.
I replaced the filter first, then tried to get it running, before settling on the pump as the culprit. I believe the filter I pulled off was the original, and according to the previous owner who is a good friend of mine, it had been bent like that for a long time and running fine. I don't doubt that a bent filter could cause issues though.
I'd really like to talk with the engineer that put the fuel filter where it is 😡🤬
probably the same dude that put the hidden bolt under the cam gear...
interesting that you went about adding a catch can, but haven't changed the location of your fuel filter yet. you clearly have the skill to do so.
