TJM T-17 install pics and info
I finally uploaded the pics from my TJM install a month ago. I have a lot more pics of the frame mounts, the TJM bumper mounts, the inside of the bumper, etc. If anyone is interested just let me know.
I took measurements of the old bumper before I removed it to compare with the TJM. Here's what the TJM will do for you (Keep in mind these measurements include the 2.25" of lift that I have):
2000 4Runner Stock Bumper
51 lbs. = stock bumper and impact bar
7.5" = distance from center of grill to point on bumper that sticks out the farthest
20" = distance from lowest point of bumper to the ground (since the lower valence on the bumper is level, this hight is for all points on the bumper.
TJM T-17 Bumper
63 lbs. = TJM T-17 bumper and mounts
4.25" = distance from center of grill to point on bumper that sticks out the farthest
22" = distance from lowest point of bumper to ground
26.25" = distance from point on bumper that sticks out the farthest to the ground
26" = distance from bumper to ground at the wheels
Based on rough calculations, this bumper increased my approach angle by about 10 degrees.
TJM T-17 Bumper
Here's info from an outdoorwire post regarding tjm t17 install weight on a 99 4Runner.
"tjm-17 with brackets and bolts came out to 67-68 pounds.
Stock bumper (and crush tube) worked out to 42-43 pounds.
Looks like the tjm T17 only added about 25 pounds"
And with regards to the approach angle, the TJM bumper no longer limits the absolute approach angle. The frame where the tjm brackets attach is now the limiting factor (though those can easily be avoided with some driver skill).
I did not weigh mine but I can tell you that my suspension did not move even a 1/16" when I swapped to the TJM. This was with OME 891's and "C" shocks. I thought for sure this bumper would compress the suspension, at least a little bit. No winch though.
Mike
Excellent post with good intel by the way. Thanks.
Mike
Wow, i'm surprised the bumpers weigh so close to one another. If that's the case in fact, I wouldn't mind going ahead with a TJM before upgrading the suspension. Did you ACTUALLY WEIGH the materials? Good specs by the way, that's a great reference.
Originally Posted by Darren
That figure doesn't sound at all right, but I'll take your word for it. You sure it's not more like 20, or so? Both of those items are extremely light. If that figure is correct, then it sure throws me for a loop. It's nice that you took the time to weigh both bumpers, for curiosity's sake.
One of the reasons that I went with the T17 is weight. I wanted to keep the weight down as much as possible so I was curious of the comparison between this bumper and my stock bumper.
Mike
Mike
I think that this is definately a mod you could do before any suspension upgrades. I'm not expecting that it will alter the ride height of the truck in the front at all. I'm glad the specs were helpful.
Hey Brad, I see you live in Menlo park, I live in EPA, but not the ghetto part. Really...there is a non ghetto part. Anyways I wanted to ask if the bumper install was pretty much plug and play? Did you need to hammer anything or weld anything. I also have a 1996, so there might be some bumper issues.
thanks for any Feedback.
Joe
Joe
Joe,
The bumper install was cake. Completely plug and play.
- Unbolt stock bumper
- Unbolt stock impact bar
- Bolt TJM mounts to stock bumper mounting points
- Bolt TJM bumper to TJM bumper mounts
That's it. Not sure if anything is different for a '96. If there is then I would guess that TJM would have different mounting brackets that are a direct bolt on for that year.
Hey Brad
Were you on the 101 Northbound yesterday around 1-2PM? I think I saw you and you looked back at me. I had a blue Klein mtn bike on the room in a black limited. It was weird, I saw at least 3-4 modified 3rd gens on the road yesterday.
I am sure it was your ride.
Anyhow, thanks for the reply and have a good one.
Joe
Joe
Originally Posted by <96 Runner>
I like it! I need one bad. How much did you get it for shipped if you dont mind me asking?
.Anyway, the bumper rocks! You gotta get one.
Nope, sorry. My truck was sitting in the parking lot at work.
That's crazy. I hardly ever see modified 3rd gens in the bay area. I see Tacos now and then, but hardly ever a 4runner.
When I said Yesterday, it was Monday, so what I meant was Sunday Afternoon at around 1:00PM
I am sure it was yours. Black/TJM and right near the Embarcadero exit on the 101 N. bound.
Looking good runner! I recently installed the T-15. Looks much burlier than the stocker.
For future measurements, weigh yourself on the scale first, then get on with the item you want to weigh, and subtract your weight. This will yield more accurate results.
Is this the steel or aluminum? Do you know the weight difference?
I finally uploaded the pics from my TJM install a month ago. You can check out the pics here. I have a lot more pics of the frame mounts, the TJM bumper mounts, the inside of the bumper, etc. If anyone is interested just let me know.
TJM T-17 Bumper
TJM T-17 Bumper
