1989 Toyota Pickup
Old Jul 6, 2020 | 06:37 AM
John Mervin's Avatar
1989 Toyota Pickup
I have a 1989 Toyota Pickup (v6 3.0). Hit a deer about 2 weeks ago and everything still worked afterwards. I go to get new housing units for front bumper turn signals. Turn signals worked after I hit deer. Go to put new units on and new bulbs and now I don’t have turn signals at all. I can’t pass inspection without them.
Since the turn signals don’t work, my tail lights stay on constantly. I have to take the hot wire off the battery now. My brother thinks the turn signal switch is “smoked” on the steering wheel column. I checked all of my fuses (under hood and driver side kick panel), they check out good. I was thinking it was a relay but according to Advance Auto and Autozone they rarely go out. I need HELP guys. Thnx a bunch
Old Jul 6, 2020 | 08:45 AM
Paul22RE's Avatar
5 Year Member
Why did you replace the bulbs if old ones were working? Maybe the new bulbs burnt out (if they were the wrong wattage)? Have a multimeter, or even a test light?
Old Jul 6, 2020 | 11:56 AM
Yea I have a test light. And I replaced the old bulbs because instead of having orange lense with clear bulb, I got clear lense with orange bulb. I put old bulbs back in and they work still. 1156’s...Problem is the bulbs won’t come on now and the tail lights stay on constantly now
Old Jul 6, 2020 | 11:59 AM
Thinking maybe the switch has gone bad...
Old Jul 6, 2020 | 12:07 PM
Paul22RE's Avatar
5 Year Member
So even with the old bulbs back in the front or test light on the front sockets, you are not getting any voltage?
Old Jul 6, 2020 | 01:09 PM
according to the test light I have voltage. I am using a battery powered test light from advance auto. What I need is a multimeter. My headlights come on when I flip the switch, so does my corner marker lights, 4 way hazards come on but no turn signal/ running lights, however, the tail lights are on. Just weird how all this is happening now.
Old Jul 6, 2020 | 01:50 PM
I have turn signals now. But my tail lights and corner marker lights stay on even after I take the keys out of ignition.
ition
Old Jul 6, 2020 | 02:16 PM
Paul, I think it may the brake switch above the brake pedal....the reason of why my brake lights are staying on. I am gonna order a new one and see if that takes care of the brake light issue, and if it doesn’t then I will order a new turn signal switch and if that doesn’t work then I will have to run down the wiring gremlin. Only thing I can do. I have exhausted all my other avenues so far..why not spend kore money in a truck? 😂
Old Jul 6, 2020 | 02:58 PM
Paul22RE's Avatar
5 Year Member
Pull the plug leading to that switch and see if the brake lights go out before you invest in a new switch.
Old Jul 6, 2020 | 03:25 PM
I will check that. I was already looking up switches too. Not too bad on the price. I did check where the button was at. It is OEM. It has completely broke off so that could be the problem. I will have to check it tomorrow. It is already too late to do it. But best believe I will though. I will keep ya updated too. Thanx for the help man. I am glad I joined this forum.
Old Jul 6, 2020 | 04:15 PM
Paul22RE's Avatar
5 Year Member
Also, you said the "test light" has a battery. That may be a continuity tester and not a voltage tester. When you touch the alligator clip to the tip of the tool, does it light up? If so, that is a continuity tester which is good for testing grounds, but not for voltage. I strongly suggest a multimeter. Those red ones at Harbor Freight are only a few bucks but work fine for most applications.
Old Jul 6, 2020 | 06:21 PM
I haven’t even tried that yet. I definitely will check that as well. It has a red LED though. I know some do check for grounds and some for voltage/ hot. I am gonna go buy a voltmeter tomorrow when I get off work. Hey, at least my turn signals work 😂. I’m just hoping that when I pull that brake switch plug in off that it cuts the brake lights off. Then I will know that I need a new BL switch. I really don’t want to have to keep jacking with this antique 😂😂. So as it stands right now, I have to put the new stuff on as well...front bumper, lower valance, ball joints, spark knock piece, and get it 4 way aligned...Also, speedometer cable busted but it still functions...so just the small stuff which is a pain in the ass but I will check the tester and get a VM...and go from there... I really do appreciate your help man.
Old Jul 19, 2020 | 06:40 AM
Yes sir
That was the issue Paul. The brake switch is faulty AF. Don’t know how that occurred but as soon as I took the clip off the brake lights went off. I kept having to undo the hot terminal of my AGM in order to keep the battery from dying out which I am about to get a new one but that was the issue. Now there is another switch located on the brake pedal, do u know what that is?
Old Jul 19, 2020 | 07:31 AM
Paul22RE's Avatar
5 Year Member
Can you take a pic of what you're looking at? I took a quick peek of my 92 and only see one switch.
DirtyGTI
Apr 7, 2020 02:36 PM
onmyway
Aug 4, 2016 12:57 PM
lmutter
Feb 1, 2016 10:30 PM
grady77
May 15, 2012 09:21 PM
