Aftermarket fuel tank
Old Mar 22, 2020 | 12:40 PM
dbittle's Avatar
Has anybody used an aftermarket fuel tank. I have a 1991 4wd pickup that needs one.
Old Mar 22, 2020 | 05:44 PM
wallytoo's Avatar
sure. spectra premium. bough it and installed in 2013 for my red ‘87 4runner. no issues, perfect fit.
Old Mar 22, 2020 | 06:25 PM
dbittle's Avatar
Thank you sir! That is what I needed to know. I got this truck not running for 7 years. It is amazingly rust free, except for inside the fuel tank. I opened it up yesterday and never saw such a rusted mess in my life.
Old Mar 25, 2020 | 10:17 AM
rattlecanpaint's Avatar
No Lie. Check Rock Auto. They have them for the 80's era trucks.
Old Mar 25, 2020 | 07:17 PM
dbittle's Avatar
Rockauto is the place! It should come tomorrow or Friday. With luck, the truck might be running next week.
Old Mar 26, 2020 | 05:37 PM
dbittle's Avatar
The Spectra premium fuel tank came today from Rockauto. It is a nice looking tank. It does not have the drain plug provision that the original tank had. I believe that I will add one and paint it flat black as the original tank was before I install it. The fuel pump bracket and sending unit aren't here yet, so I have time to mess around with it some.
Old Mar 27, 2020 | 03:18 AM
wallytoo's Avatar
true, no drain plug. i’d forgotten that. but it isn’t a feature i need. the pump can be drained using the fuel pump jumper and a hose connected to the tank return line off of the FPR, directed into a suitable container.
did this with my ‘97 corolla prior to junking it, although there is no jumper.
Old Mar 27, 2020 | 04:28 AM
old87yota's Avatar
Well, only if the fuel pump works.....
Old Mar 27, 2020 | 08:56 AM
dbittle's Avatar
I was surprised to see the drain plug on the original tank, to be sure. I think it mighr be useful to.me though, so i will add it now while i can without a lot of hassle.
Old Mar 27, 2020 | 04:07 PM
wallytoo's Avatar
true, but in a 4r, the fuel pump can be swapped/replaced without dropping the tank, so if the tank needs to be emptied, there is a simple solution. just put in a functional pump.
Old Mar 27, 2020 | 06:14 PM
dbittle's Avatar
We occasionally lose power for a few days due to weather events, although admittedly not very often. If the outage lasts a few days, I usually start siphoning gasoline from the tank of my vehicle to run the generator. This truck tank holds 19 gallons and is set up from the factory for convenient access. For me, it's worth the $5.99 for the Dorman drain plug kit. It's actually the first vehicle I have come across that had a factory drain plug in the fuel tank. I was really surprised when I saw it there. The guard plate under the tank is recessed for it, so I have no doubt its OEM.
Old Apr 3, 2020 | 07:32 AM
maxvp01's Avatar
I actually just installed the Spectra premium fuel tank from rockauto, bolted right up, no hassle at all!
I went ahead and replaced the fuel pump bracket, sending unit, filter neck and vent. (looked like my sending unit hadn’t worked in years)
Old Apr 3, 2020 | 08:06 PM
dbittle's Avatar
Thats about how mine looked too. Tank looks great!
tlover79
Oct 27, 2019 11:04 PM
Lewis
Feb 21, 2016 01:45 AM
rebelrick
Apr 20, 2011 12:20 PM
modlite
Oct 24, 2010 05:28 PM
