Co relay
Old Feb 24, 2020 | 07:54 AM
Bjw1285's Avatar
Co relay
Where is the CO Relay located on 1988 Toyota pickup?
I needs to be replaced and im not sure where it is located or how it looks?
Old Feb 24, 2020 | 09:32 AM
BlackPearl808's Avatar
Short answer: Use the Search Tool! Many threads on how it works and how to test it.
even shorter answer: beside glove box, under the panel
Old Feb 24, 2020 | 11:27 AM
2ToyGuy's Avatar
In other words, right side kick panel, right above the ECU. The computer. You can just take the bolts off the ECU, and move it out of the way without disconnecting the ECU. Just let it hang on it's cables. The COR is right above it.
One bolt holding it in, easy to get to.
One cable plugged into it. Once it's not attached to the side any more, the cable is easy to get to.
It was about $50.00 or so at the local dealership. Took a while to describe what it was and where it was so they could find it. Kinda sad for a dealership, really.
Good luck!
Pat☺
Old Feb 27, 2020 | 09:02 PM
RAD4Runner's Avatar
And how do you know it needs to be replaced if you haven't even found it?
Old Feb 29, 2020 | 07:44 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Good luck!
Pat☺
Yeah, I find it easier to look up the part number first, then I give the counterman the vin so they can make sure I got the right application.
Old Feb 29, 2020 | 04:58 PM
scope103's Avatar
I was wondering that myself.
Personally, I think it quite unlikely that you can determine your COR is bad without testing it out-of-circuit. Yeah, they're only $105 https://parts.lakelandtoyota.com/p/T...591014020.html , but if it's not broken, replacing it won't fix anything.
Old Mar 9, 2020 | 08:23 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
" Yeah, they're only $105 "
Thats like 50 lotto tickets or so.
mengquis
Aug 4, 2014 08:01 AM
4runner350
New England
Sep 9, 2011 06:16 PM
the47guy
Aug 21, 2011 10:19 PM
mitch101
Aug 27, 2009 11:27 AM
