What the difference in CA 4runners and the rest of US 4runners?
I have been trying to find a good 4runner around Reno to buy, and all are in CA. What has been modified/restricted due to CA's emissions laws?
Thanks
Tim
Thanks
Tim
Nothing on the newer trucks. On the older 22RE trucks there was the 22REC engine which had a litle more emissions crap than the standard 22RE. Now they build them all the same which means they build them all to California specs.
Dude, EVERYONE in California has Yota's.
I bought mine in Phoenix....super cheap and no rust or corrosion!
Yeah, I dont htink there is anything different between the trucks now adays.
Originally Posted by unr.frosh
So the 2000 4runner I'm contemplating buying will have two cats? Can I jsut take it to a shop here and have them cut one out and replace with a straight pipe.
If you get a dual cat, save yourself some hassle and just leave it in. You'll be polluting less and will take a minimal (what, maybe 3hp? at the most) power loss.
Originally Posted by 3.4Runner
in 99, the CA-spec 4Runner came with dual cats and the rest had just one cat. In 2000, they all came with dual cats...there is some confusion regarding the sensor before the first cat. Some have an AFR sensor and others have another O2 sensor.
Originally Posted by toy283
Except that AFR sensors and O2 sensors are the same exact thing. That is the purpose of the O2 sensor, to measure air/fuel mixture and send a signal back to the ECU so that it may correct the mixture as needed. The purpose of an O2 sensor after the cat is to measure cat operation. This signal isn't used by the ECU so much for mixture control as a possible trouble code source.
creed
Starting in 99, the trucks bound for CA had the dual catalytic converters and the front AFR sensor.
My .02
G
I remember reading window stickers on brand new 1996 models and it said California Emissions and Im in New York, it was even in the brochures.
Now it is just standard and accepted, the air here is just as dirty as California
the smog makes my eyes water
Originally Posted by Birdman
The air is fine here in Santa Cruz. Not everywhere is smoggy like L.A.
Can someone tell me if my new to me 2001 Toyota 4RUNNER which I bought in Massachusetts would be CA emissions compliant. May move out there in the next year so I would like to know. Is there a way to find out if a particular vehicle was originally CA emission compliant?
Matt
Matt
Ken
Matt
Matt
I was going to post about this matter... Funny how the thread suddenly reappeared right as I was thinking this...
I hope it's true that fed emissioned vehicles would not need to be modified to meet CA emission standards before being registered in CA....
I bought mine from a dealer here and the vin shows it as fed emissioned.
I just ordered a non CA precat O2 sensor and hope it wasn't retrofitted with the new AFR crap....
The non CA sensor was only $90 while the CA one is $270... :X
