EGR valve connector question
I am working on a 1995 3vz engine swap into my 88' 4runner and am trying to figure out the EGR electrical connection. The connector on the engine harness has a plastic cap on it that shorts the pins. Is this indeed the engine wire harness connector for the EGR valve? I also have a single pin connector on the harness in close proximity to this connector but I think that's for the AC compressor.
The Connector to the EGR valve is the EGR Gas Temp sensor http://web.archive.org/web/200605091...43egrgaste.pdf I believe (according to the FSM) that it is only present on California vehicles, and probably not at all in 1988 (the manual linked is for a '93). Meaning you don't need to/can't connect it to your '88 ECM. But I will defer to those with more electrical experience on that vintage vehicle.
