2nd Gen Springs
Old Apr 17, 2004 | 05:56 PM
Godzilla's Avatar
2nd Gen Springs
Im replacing my rear coil springs (keeping it stock size) for the 92 4runner, and would like to know the difference between the heavy duty and variable rate springs..any thoughts or suggestions?
Old Apr 17, 2004 | 07:30 PM
NCSU-4runner's Avatar
id recommend the downey HD springs, they ride great and never wear out like the stock springs. the ride was never harsh or stiff, get some good shocks too, you'll never regret it. Heres some pics of various springs side by side. Stock -> downey HD -> OME 860. I've never driven a progressive rate spring before, so i cant make reasonable judgements about them.
Old Jul 3, 2004 | 02:59 AM
914runner's Avatar
Holy crap those OME 860 springs are huge compaired to the downeys!
The 860's are from a cruiser right?
Old Jul 3, 2004 | 07:20 AM
yes, OME 860's are rated at a 2.5 in lift for an FJ-80 lancruiser, they yield about a 5 in lift on a 4runner
Old Jul 3, 2004 | 07:51 AM
yotafool's Avatar
Are you running those OME 860's with your 35"s?
Old Jul 3, 2004 | 08:02 AM
yes, they easily clear 35s, i also have a 2in body lift but its not for tire clearance. i use the body lift to accomidate my drivetrain lift and accomidate my new gas tank under the rear of the truck. I should have nearly a flat belly when its all done
Old Jul 3, 2004 | 08:07 AM
yotafool's Avatar
Nice man, do you have a website with any pics? Id love to see what you have created. Sorry to stray a little from the topic. I've hear only good things about the Downey HD coils. I have 4" superlift supersag coils now. :cry:
Old Jul 3, 2004 | 08:52 AM
those downey HDs are sitting in my garage, for sale if you want em, you'd probably want some spacers too to level out the 4in IFS lift front
Old Jul 3, 2004 | 10:33 AM
914runner's Avatar
Or you could go with the OME 860's and 1.5" BJ spacers in the front.
EDIT: Do the OME 860 coils have a long side and a short side like the stock cruiser coils?
Old Jul 3, 2004 | 11:54 AM
M3TA4's Avatar
Here is a pic of my truck with the performance products springs, they make it look great.
Old Jul 3, 2004 | 01:55 PM
yes they have a short side and a long side, but yes you have a stock gas tank on one side so its not a problem, the taller spring goes there.
Old Jul 3, 2004 | 03:04 PM
914runner's Avatar
So in the end it sits level with the tall side on the gas tank side?
Thanks
Old Jul 3, 2004 | 03:06 PM
i cant say it would be 100% level but should be pretty darn close, not enough that you could ever tell by looking at it
Old Jul 3, 2004 | 10:25 PM
914runner's Avatar
I guess you could use OME trim packers to level it out right?
Old Jul 4, 2004 | 07:37 AM
if it bothered you that much it wouldnt be hard to shim it with a thin spacer, i'm not familiar with the OME ones you speak of but i've never looked around for them
Old Jul 4, 2004 | 07:48 AM
yotafool's Avatar
Hey NCSU, when you put the OME860's in did you by any chance also get the longer adjustable upper rear control arms? If not have you had any problems?
Jun 1, 2021 01:51 PM
Rasteirinho
Nov 6, 2017 03:40 AM
rocket
Jan 21, 2016 05:03 PM
vanion2
Jul 29, 2015 06:17 PM
Steezy96yota
Jul 6, 2015 10:00 AM
