Clutch fork clips missing
Old Aug 22, 2019 | 02:02 PM
Neemox's Avatar
Hey all, I just installed a partially rebuilt 22RE last night, putting everything back together the way I pulled it apart. My clutch fork is missing, and apparently has been missing the little clips that the FSM calls out. I only had the picker for a night, so I dropped it in anyway, please tell me those clips aren't so important?
I've apparently been running without them for about 25k miles (since the last engine went in) at least. I am planning on doing a full re-build on the engine I just pulled out (the saga continues...) and so when I put it back in it'll be with all the trimmings, new clutch, new head, new everything, including clutch fork clips, but can I get by for 10K miles without the clips or do I need to go rent the picker again and pull it apart?
Old Aug 23, 2019 | 06:02 AM
keycw's Avatar
5 Year Member
I feel like your probably just gambling at this point. they are important, because they hold the bearing cup to the fork, but obviously its not preventing you from driving. probably just putting wear and tear at an accelerated rate. I don't see how the bearing would come back like its supposed to without staying on the fork though.
Old Aug 23, 2019 | 06:18 AM
Neemox's Avatar
Is there a spring in the clutch fork that pulls the bearing back? Seems like maybe my clutch is even more screwed up than I thought...
Mine doesn't seem to have any real spring, just the tension from the rubber boot. I assumed that the clutch diaphragm pushed it back, but sounds like that is wrong.
Old Aug 23, 2019 | 06:27 AM
keycw's Avatar
5 Year Member
the fork just comes off when you let off the pedal, the bearing has to ears on it, and the clips go over the ears and under the fork to attach it, the fork has a clip on the back of it that goes onto a little ball that keep the pivoting in the middle. no springs.
Old Aug 23, 2019 | 06:32 AM
Neemox's Avatar
OK, thanks for the info. Sounds like everything is as it should be then, just no clips. No I have to decide to pull it out again or not. I should have probably figured that out before I started bolting peripherals on...
Thanks!
Old Aug 23, 2019 | 06:40 AM
keycw's Avatar
5 Year Member
Thanks!
I don't see why you should need an engine puller for the job. the tranny is pretty straight forward to pull. bellhousing, crossmember, driveshafts.
Old Aug 23, 2019 | 06:43 AM
Neemox's Avatar
Hahahah. Oh man, That's what I get for always overcomplicating things. Somehow I forgot that now that the engine is back in, I could just pull the transmission instead of pulling the engine back out.
Thanks man! I'll find some clips and get it done. That's a much easier way to go about this.
Old Aug 23, 2019 | 08:51 AM
Paul22RE's Avatar
5 Year Member
Get a surgeon with microscopic tools and camera to put clip on though the fork hole...
Old Aug 24, 2019 | 08:41 AM
keycw's Avatar
5 Year Member
All those little pieces are still available from Toyota. I think marlin also sells them.
Old Aug 24, 2019 | 09:35 AM
scope103's Avatar
No engine puller ("crane") needed, but you'd be well advised to get a transmission jack. I once removed a transmission with a trolley jack (and some c-clamps to hold the transmission to the jack). Never again.
Old Aug 25, 2019 | 04:25 PM
Neemox's Avatar
This is good advice right here. I would have tried to do it with just my regular harbor freight floor jack and really regretted it likely.
Old Aug 26, 2019 | 07:29 AM
keycw's Avatar
5 Year Member
x2 on the tranny jack and I highly recommend one that pivots a little bit. the upper driver bell housing bolt is kind of a pain but everything else is straight forward,
Old Nov 23, 2019 | 11:05 AM
Tims86Toy's Avatar
Found a website that carries the fork release clips...
https://www.megazip.net/zapchasti-dl...-fork-17782806
Dauntless1971
Jun 10, 2018 12:08 PM
lmobeats18
Aug 28, 2015 04:57 PM
dlucky894runner
Jun 21, 2011 01:16 PM
toyotanick
Oct 27, 2009 10:00 PM
Gerdo
7
Mar 26, 2006 07:56 AM
