Snap-on mt2500
Old Apr 24, 2019 | 10:01 AM
Jakez's Avatar
Snap-on mt2500
So is it true, will these scanners read various sensor data from the diagnostics port under the hood?
Old Apr 24, 2019 | 10:48 AM
millball's Avatar
It is true, if the MT2500 has suitable software cartridges installed.
I can say that the data available varies, depending on the year. My '95 will tell more than my '87 will.
I was able to set the TPS on my '95 with the engine running; using the data the MT2500 displayed.
I remember that the scanner could determine open and closed loop operation on the '95.
I have two cartridges that I use:: OBD-1 Asian vehicle interface and OBD-1 Asian vehicle fast-track troubleshooting. There may be others. IDK.
I have had no recent troubles that have necessitated use of this scanner on my OBD-1 Toyotas so my memory of exactly what data is available is weak.
It certainly is able to do more than merely display the numerical codes.
It goes without saying that you must have the correct adaptor to plug into the Toyota diagnostics port.
Old Apr 24, 2019 | 11:27 AM
scope103's Avatar
I have one of these:
https://www.zf-scantools.com/
It's an excellent piece of hardware (software described here: http://jfbreton.blogspot.com/2014/07...-overview.html )
BUT: they're out of stock! You could send Jean Francois-Breton a note, but I suspect that he was selling into a rapidly narrowing market, and has moved on. Yeah, it's the story of OBD-"1".
Old Apr 26, 2019 | 11:43 AM
Jakez's Avatar
Does anyone know which adapters and/or accessories I will need for a 1993 Toyota Pickup 4x4 22re?
I just bought this, which is just the scanner box alone:
https://www.ebay.com/itm/Snap-On-MT2...pid=1411827082
Old Apr 26, 2019 | 03:35 PM
millball's Avatar
To start, you need MT2500-5000 (500???) cable and TOY-1 MT2500-50 adaptor.
These will get your scanner plugged into your Toyota OBD-1 truck.
You'll have to search for suitable software cartridges.
The cartridges I possess were the latest programable kind made for this scanner and they were loaded by the tool truck guy, years ago.
They are good for most domestic and imports from the early '80s up to 2003. (given the correct adaptors to connect to the various manufacturers OBD-1 plugins) I think that's about the time the MT2500 was superceded by a newer scanner model.
Old May 13, 2019 | 12:02 AM
Jakez's Avatar
.Here is what I have bought so far:
A couple issues I'm having now are: how do I power it so I don't have to keep the button held down the whole time? I feel like this is the cause of my 2nd problem: I can get all the way to the screen where it says I can release the button, but when I do that it shuts off.. shouldn't it get power from the toy-1 adapter?
Thank you all so much! Scope, I will try my best to get my hands on one of those, I've seen a video with an iPad on the dash showing all kinds of data, it looks pretty awesome!
Old May 13, 2019 | 11:51 AM
Kolton5543's Avatar
I use a Snap-On Modis EEMS 300. It works good on anything pre 96. On my 94 it showed lots of different data. Has most of the stuff you'd find on regular OBDII cars inlcuding fuel trims, O2 voltage, TPS voltage, ECT, RPM, timing advance and a few others. It's a pretty capable machine, just cumbersome to use.
Old Jul 15, 2022 | 06:06 PM
Srsapo's Avatar
Holding Button
The button is just a test of operations. Some of the connections made to the vehicle being tasted will provide the operational power. The Snap-On book says for Toy-1 adapter use that a separate power supply is needed. There is a battery pack available or you can use the plug in power adapter to power the MT2500
arnolddf
May 17, 2018 07:07 PM
MTL_4runner
Oct 3, 2006 04:34 AM
NicksBlue934runner
Jun 21, 2006 07:19 AM
Mikronized
17
May 22, 2005 04:58 AM
Tacotex
Mar 26, 2005 07:55 AM
