What seats you got?
Old Feb 16, 2019 | 02:01 PM
87-4runner's Avatar
What seats you got?
These will do till i get my factory ones fixed...
Old Feb 16, 2019 | 02:18 PM
wallytoo's Avatar
originals in both '87s.
as bought
with covers
Old Feb 16, 2019 | 04:26 PM
87-4runner's Avatar
Nice...
Old Feb 16, 2019 | 06:29 PM
wallytoo's Avatar
my other '87 has the same version you have in red, mine are grey. they are more comfortable because of the adjustability.
Old Feb 17, 2019 | 12:45 AM
SomedayJ's Avatar
I have the originals also.
I like the 4Runners first gens with vynil seats and door panels. Yours has a perfect interior, I love it!
Old Feb 17, 2019 | 09:55 AM
se7enine's Avatar
I'm using these Tiburon seats currently. If I could afford it I would have some nice Recaro Experts.
Old Feb 17, 2019 | 10:29 AM
dropzone's Avatar
Fossilized
i took the early 90'ish prelude seats from the Trekker and put them in the 4runner. no pics of the brackets I made for the rear inside and outside mounts but they are pretty much bend some flat stock to work
The prelude seats have been great due to the adjustments they have
I believe 2nd gen 4runner mounting locations are pretty dang close to 1st gen 4runner and 2nd gen trucks
added links to the two post quotes because it looks like the attachments from the quotes may or may not show up
https://www.yotatech.com/forums/f199...l#post52339845
Originally Posted by dropzone
My driver's seat is ripped in the typical spots for a 20+ year old 4runner with close to 200K. It has also reclined one me a few times while driving like the ratchet mechanism was about to die. Not a good thing to happen I had looked around for a good replacement but no luck finding one that was cheaper than what I paid for this thing
Several years ago I installed a set of 96'ish Prelude seats in the Trekker. I had replaced those with a set of suspension seats. Attempted to sell the Prelude seats and even tried to give them away..No luck, they sat in the garage for a few years. They are still in great shape so I busted out the tape measure.
busted out the tape measure...front mounts were 16.75" on the 4Runner seat
hmmm...Prelude seat front mounts are 16.75"
Attachment 112070
i throw the seats in the 4Runner to test fit..the inside mount for the prelude mount of course hits the seat belt mount causing it to cock the seat at the wrong angle
Attachment 112071
Attachment 112072
At first i thought about picking up some camry or corolla latches that would mount to the seat rail similar to the prelude latch. I was gonna have to make a mount to the inside rear corner any way, so I cut that sucker off and mount the seatAttachment 112073
pretty cool that the stock front mounts work perfect
outside rear mount will get extended tomorrow with some flat stock. Inside rear should be a simple 'L' bracket.
Attachment 112074
it will end up being bolt in install..
Not a perfect match but i think it will work
Attachment 112075
Attachment 112076
I will be able to finish the install in the morning
https://www.yotatech.com/forums/f199...l#post52339927
They don't look half bad
Attachment 112055
Old Feb 17, 2019 | 03:00 PM
87-4runner's Avatar
Very nice guys!
Old Feb 17, 2019 | 03:09 PM
dropzone's Avatar
Fossilized
what is the width of the front mounts eye to eye?
Old Mar 22, 2020 | 09:29 AM
Ram1's Avatar
Seats 96 Toyota t100
Anyone out there know what type of seats are close to fit for the T100? I'm 6'5" tall and the factory buckets just don't go back far enough. A little more comfort would be nice too. Thought about trying Tacoma TRD seats but haven't found any as of yet. Any ideas will be appreciated. Thanks.
Old Mar 29, 2020 | 10:20 AM
jgrant721's Avatar
When the original fabric my '91 4Runner started to fray, I found some very nice leather sport seats from an Audi TT on ebay.
Old Mar 29, 2020 | 05:48 PM
dropzone's Avatar
Fossilized
i replaced the prelude seats with these- truck has been sitting for over a year so haven't driven it yet
I hear ya!
Thanks, I think the dimmer will work out
Still running the FJ80 rear springs..no real issues with the gas tank. Stock arms.
My plan is to convert to rear leaf springs at some point . I have all the stuff to do it but just not the time.
So yes I know I need to get off my butt and finish the dual case install but have been working on house junk (painting and getting ready to fill in our inground pool)
Anyway been debating replacing the Prelude seats I have had in 2 different trucks. I was going to convert them to heated seats but the Amazon kit I bought a couple of years ago was dead when I finally went to use it.
Pick n Pull has a 50% off sale this weekend.
Decided to cruise through there today to see what I could find as far as seats.
After looking through about 100 cars I ended up with a set of heated, power & leather seats out of a 2005 Subaru Outback. The front mounts measured about 16.5" center and center..same as the stock mounts.
Got them home, tested the motors, they worked great and powered up the heaters..got toasty warm which will be nice this fall.
Spent some time cleaning them up.
Jumpered the motor and heater controls using a drill battery.
It all worked as it should. Seats got nice and toasty
link to video on Instagram
https://www.instagram.com/p/Bx3A4T8A...=1ibj42ta91fni
The passenger seat was already out of the 4runner for the dual case install. I was very happy to find that not only did the front two mounts line up but the outside rear mount was a dead ringer too!
I will have to cut the inside rear mount to make it work (as it is now it gives the seat a slight lean)
But for $45 for the seats and heated seats switches I am happy with them.
I will do a leather dye experiment on either a headrest or inside of the seat to see if I can get them gray.
The seats end up about 1" higher than the Prelude seats I have mounted into there now
Last summer I picked up a set of 2008 Forester power leather and heated seated to put in the 4runner. Surprisingly 3 out of the 4 Subaru mounts line up perfectly with 3 of the 2nd gen 4runner mounts.
The seats are in great shape, downside they are tan. For the price I paid a U-Pull It I figured i could experiment with the seats like i have pretty much done my whole driving life. In my Air Cooled V-Dub days I used vinyl dye several times, even on leather. Ordered a can of Charcoal Rustoleum on Amazon and shot one of the headrests with it.
3rd pic shows the tan against the stock door panel and the sprayed headrest again against stock vinyl.
It came out pretty good so decided to take the plunge and see how the passenger seat would come out. Doing several light coats and waiting awhile between each one it's looking pretty good.
ordered 4 more cans off amazon.
That should be enough to finish off the seats.
95extracab
Aug 6, 2018 07:13 PM
Man4God
Oct 1, 2012 10:39 PM
FOCUSHERE
Oct 27, 2006 12:27 PM
Tacoma Dude
Apr 18, 2006 09:27 PM
RED 85
24
May 30, 2005 11:33 AM
