Diagnosing a 1994 Pick up running ruff
Hey Guys,
I'm new to the site,and would appreciate some advice.My son has his grandfathers 94 Pick up with 60k miles.
Before we gave it to him a year and and a half ago.Put a new distributor,wires,cap and plugs. She ran pretty well,but always had what felt like a miss.
Not being a mechanic,we took it to one.They changed the fuel filter,it ran a little better but never fixed.A year later and it seems to be getting worse.So far he has changed the plugs,
Cleaned the mass air flow sensor,and checked the throttle position sensor. He says the engine runs better with the TPS unplugged. Which I didn't think sounded right.to me.
We got a fuel gauge to test the fuel pressure,Instead of I believe 32lbs it was 80 lbs he also says he gets getting a code 24.
Does anyone have any idea what may be causing his problems,beside the nut behind the wheel.
Thanks in Advance
Pat
Thanks in Advance
Pat
Code 24 is intake air temperature sensor signal. The IAT sensor is in the VAFM (what you referred to as MAF sensor), that could cause the rough running. How was it cleaned?
What engine is it? The is a lot of info on this forum regarding testing the VAFM, or if we know what engine, I can provide a link to the procedure.
Also, fuel pressure regulator return line blocked or valve stuck closed?
Welcome to YotaTech!
80psi is WAY too high; here's the spec: http://web.archive.org/web/201501160...28fuelpump.pdf I'm surprised you don't also have code 26 (Rich malfunction), but I'm not surprised it's running poorly.
A failed FPR could easily do that, but as AZ4runner suggests, I would first check the fuel return line. Just replace the line (at the FPR) with a 6mm (1/4") clear vinyl tubing to a suitable container. Use the jumper to run the fuel pump without starting the engine, then repeat the fuel pressure test. (While you're at it, you should get about 1/2 liter/min out of the return line.) If the fuel pressure drops back into spec, you probably have a blockage downstream in the return line.
[QUOTE=az4x4runner;52413251]Code 24 is intake air temperature sensor signal. The IAT sensor is in the VAFM (what you referred to as MAF sensor), that could cause the rough running. How was it cleaned?
Hi az 4X4 runner thanks for the reply,
My son said he made a mistake it is coming up code 25,also he said he used MAF sensor cleaner
he has a 22re
"Also, fuel pressure regulator return line blocked or valve stuck closed?"
This was mentioned several times,I will hopefully be checking that tomorrow after work.
Welcome to YotaTech
