Is this the knock sensor harness?
Old Oct 26, 2018 | 12:06 PM
cabledawgrunner's Avatar
I had to replace the power steering pump hose and when I did I knocked this wire out of the connector. After doing a little research I thought it was the knock sensor harness. I ordered one and it doesn’t fit (all the reviews say direct fit) and it’s really short. I’m not sure what those wires go to now. Does anyone know what this is? I do know my engine has started running like crap ever since I broke it.
Old Oct 26, 2018 | 02:13 PM
scope103's Avatar
Originally Posted by cabledawgrunner
... I knocked this wire out of the connector. ... Does anyone know what this is? ...
I'll bet you intended to attach some photos. Give it another try.
Old Oct 26, 2018 | 03:57 PM
Yeah I did. I can’t do it on my phone for some reason. Is there an app that works with yotatech? And I found out my dumbass was looking at the egr hahaha you live and learn.
Old Oct 26, 2018 | 04:26 PM
scope103's Avatar
Then you should have code 71. That will dramatically retard the ignition timing to save the engine. "run like crap."
Old Oct 27, 2018 | 05:51 AM
I don’t have and OBD1 to check and there is currently no light (doesn’t mean there isn’t a code). I did try splicing the temp sensor and the wires that go back to Ecu. I unhooked the negative terminal for a couple of minutes to try and reset it and I still have no luck. I am not sure why I cannot add an attachment. I have tried multiple times. As soon as I hit the upload button after selecting the image it goes back to this page.
Is is there a different way of resetting the ecu once the connection is re-established or am I going about this the wrong way? Thank you again for all of your help
dbd6604
Oct 23, 2015 07:16 PM
big1000
Jan 18, 2013 04:13 PM
jodynich
Sep 28, 2009 08:03 AM
Michigan Mud Farmer
Feb 8, 2008 12:58 PM
tlake
Jan 30, 2008 08:53 AM
