32x11.50s rub A-Arms with 1.5” BJ Spacer, OME T-Bars, Stock SR5 Wheels
Will 32x11.50s rub A-Arms with 1.5” BJ Spacer, OME T-Bars, Stock SR5 Wheels
As the title says, worried about these tires rubbing when I go on Fri to get them mounted. Setup:
- 1.5” 4Crawler BJ Spacers
- OME T-Bars cranked for 1” add lift
- Upper A-Arm lip trimmed
- 235x75R15 tires in the pic
- 32x11.50 KO2s will be mounted Fri
Pica attached. Thoughts?
You might want to lose the shipping label in that one picture. Your full name and address is on display for the world letting them know where to come pick up brand new 32" in tires and a freshly painted classic vehicle.
I have 33x10.50s, with BJ spacers on factory steel rims and mine rubbed. I added 1/4" wheel spacers, I did not grind lip of my a arm. I'm not sure if the backspacing is any different on those alloy rims or not. You might get lucky, but I would not count on it.
Hopefully my SR5 wheels will make the difference. If not, I may need a 0.75” wheel spacer.
It sounds good.
Do you have the first gen alloy rims or the second ones? They look similar, but the first ones have 15 offset and the second ones 8.
1st gen: 15x7JJ-15 DOT (if Iam correct, you don't have this info in the rims).
2nd gen: 15x7JJ-8 DOT (you have this info in the rims).
Don't quote on me this!
It sounds good.
See pic - is this good or bad?
I think (don't quote me on this!) in your case, the smaller the offset the better. Negative offset 'stick out' more than the positive ones. So 8 should be better than 15.
I'm not sure, lets wait for the experts.
