86 Toyota pickup not starting!!!!! Does one click when I turn the key
Hello everyone, I'm new to the forum and I don't know if this is the correct thread to post on but here we go. I have an 86 pickup that won't start and I don't know what else to do. This all started after I installed an aftermarket tach. The truck does one click with each turn of the key. I've changed the starter in which it still had the same symptoms. Then I changed the battery and it started. I drive it around for a while and it was fine until a couple of days later when it started exhibiting the same symptoms again. I bought a battery charger/ engine starter and still nothing. What should I do next?
2) The tach was installed,
3) Problem began.
What did you connect each wire to - specifically? Pictures can = 100 words.
You wrote: "The lighting wires were connected through the fuse box on the lower 15 amp and the left 20 amp"
That is written like your taking power from 2 hot sources?????
I literally just copied what the guy did on the video. I don't have an SR5, the guy on the video said it was a cluster connector for an SR5 option I guess. It's a green connector that wasn't connected to anything just like the one in the picture, so I cut it off and spliced my power wire to. Not really sure to be honest. And I literally just wrapped the wire around on end of the fuses and plugged them back in. It was working for a couple days then ceased to start. The guy in the video was attaching his to an 83 pickup but it looked similar to what I have.
A tach (even badly installed) usually has nothing to do with turning the starter. Somehow you've blown a fuse, broken a wire, or run down the battery. To figure out which, put your multimeter on the battery posts. Should be about 12.6v; if less than 12.1 the battery is discharged. (Charge it.) Have someone turn the key while you watch the voltmeter. If the battery drops by 0.4v or more, and all you get is a click, you have a bad battery. Take it to an autoparts store; they'll test it for free with a "carbon pile" tester. Move the multimeter leads to the battery clamps and repeat. NOW if you get a 0.4v drop, your battery clamps are loose. Just keep working TOWARD the starter. If you get battery voltage to ground on the big wire to the starter, AND about 11v to ground on the small wire with the key turned, then AND ONLY THEN you can consider replacing the starter.
just wrapped the wire around on end and cut it off and spliced my power wire are neither good or safe connections
Second, get and install a fire extinguisher in your truck. Actually ATTACH it, with hardware - not tape, to something made of metal.
Third, based on what I've read here, a 1st Gen and an 86 are not very similar. Note that there are different sections here for both.
The "green connector that wasn't connected to anything" HAD a spade type connector inside - cutting it off was a BAD idea.
Don't blindly replace parts. We'll help u verify which are really bad. Keep it as simple as possible. That's the reason why we have first-gens.
Was that video for ur year-model truck? Next time u have a question, please put us at ur vehicle. Share docs for what u r working with. Pls see signature.
So I'm not sure if this fuse has anything to do with the vehicle starting but the 80 amp fuse looks corroded, so that would be my next step of something to change, what do you guys think? I'll post pics soon
I haven't heard that you have made any measurements with a multimeter. (Don't have a multimeter? Absolutely no excuse for that! https://www.harborfreight.com/7-func...ter-63604.html)
Replacing parts that just "look corroded" will bankrupt you pretty quickly. All electrical parts can be easily tested first.
Next, you may have blown the fusible link which you should test. So back to Scope's response.
Edit profile and look for a signature editing link on the left side somewhere. Might need to click around within your member profie
I see a trend with a lot of new folks going on here despite the over-abundance of social media. Just more proof that sites like this will not be phased out.
Welcome to Yotatech!
