Steering Column u-joints
Old Apr 19, 2018 | 09:33 AM
NYHumpinUtah's Avatar
Hi all
Just got off the phone with Toyota parts dept, I am looking for the u-joints that go in the steering column both the upper and lower. He tells me that the u-joints are not sold individually, that they are part of the upper column and lower column. Could this be? They look like regular u-joints with the clips on the outside of the joint. Mine are loose but I guess ok but would like to replace them while I've got it torn down. Here's some pics
Sure could use some help in finding replacements
Thanks
Old Apr 19, 2018 | 06:13 PM
L5wolvesf's Avatar
There are some on eBay search - Toyota Steering UJOINT KNUCKLE 4Runner Pickup
Old Apr 19, 2018 | 08:25 PM
That is not the same part
I did however find a part # 37402-10020, but still can't find any available
Old Apr 19, 2018 | 10:47 PM
Co_94_PU's Avatar
Lmgtfy... Third response is a megazip source...
Other option would be to measure it and go from there.
Old Apr 23, 2018 | 07:14 PM
Why is it that all your responses never make any sense................
Old Apr 23, 2018 | 08:26 PM
old87yota's Avatar
Lets see if I can translate; it took me a minute:
Lmgtfy = Let Me Google That For You
The third Google result for part # 37402-10020 is an OEM parts supplier located in Japan that may have parts that have been discontinued in the U.S. That company is called MegaZip: https://www.megazip.net/zapchasti-dl...der-3740210020
The other option is to take the U-joint apart and measure the parts to see if you can match up another U-joint from another car to use.
I think I translated correctly.
Old Apr 28, 2018 | 10:44 AM
SENOR NOODLES's Avatar
I have a brand new one in my tool box at work. From Toyota. They were bought individually about 13 years ago. If it is still complete I will post here and let you know if I have one. I think the part number is gone.
Old Apr 28, 2018 | 10:45 AM
Personally I would find an older one and ditch the rag joint.
Old Apr 28, 2018 | 12:01 PM
I will get some sizes for you so you could compare
Thanks
Old Apr 28, 2018 | 01:43 PM
Sounds good to me.
Old Apr 28, 2018 | 06:30 PM
Thanks
Ok, Cap Dia = 19.8mm ( .780in) Length = 55.76mm ( 2.197in) As close as I can get with them still installed
Thanks
Old Apr 30, 2018 | 08:07 AM
I got approximately the same. 19.98mm on cap diameter 58.3mm uninstalled length. I have 2 of them. I will give you one for the price of $free ninety free.
Old May 2, 2018 | 06:36 PM
Many thanks to SENOR NOODLES, he had two of these and sent them out to me. Need more people like him!
Thanks again
Old May 4, 2018 | 05:25 AM
thefishguy77's Avatar
Good deal.
grimpy
11
Jan 31, 2023 09:46 AM
spddm0n
Oct 12, 2017 05:36 AM
moroza
Dec 31, 2014 01:24 PM
J'S LTD 4RNR
Oct 12, 2007 09:49 PM
bsptaco1
Sep 8, 2007 04:55 PM
