Pre 84 Trucks 1st gen pickups
Towing a first gen 4x4 via dolly?
Old Apr 12, 2018 | 06:28 PM
95yoda's Avatar
Okay so we're moving about 300 miles away and due to having too many vehicles and not enough drivers I want to tow my 82 behind the uhaul. I was going to use an actual uhaul trailer but after seeing one, im not sure my long bed will fit on the trailer? It looks pretty short.
so if it doesn't fit on a trailer would I be able to use a dolly? Would I need to remove front driveshaft or something?
I know usually you have to have a 4x4 off the ground.
thanks
Old Apr 12, 2018 | 06:48 PM
dropzone's Avatar
Fossilized
If you use a dolley Remove the rear driveshaft, its only 8 bolts
the rear output bearings don't get lubed
your long bed would fit on a u haul trailer. My 4runner fits on one
Old Apr 13, 2018 | 08:34 AM
95yoda's Avatar
Okay that's good to know. Do they have the same wheelbase? I'd rather flat lowcon a trailer than a dolley.
Old Apr 13, 2018 | 10:53 AM
jakey poo's Avatar
This is on a uhaul flat tow, plenty of room for it.
Old Apr 13, 2018 | 11:07 AM
95yoda's Avatar
That's awesome thank you! And yours is a long bed too? I'm glad I don't have to use a dolley
Old Apr 13, 2018 | 01:48 PM
jakey poo's Avatar
That's a short bed, but there was a few feet behind the rear tire. I think the long beds are 9" longer in wheelbase?
Old Apr 14, 2018 | 07:15 AM
95yoda's Avatar
Okay that's good to know. Should work fine then.
Old Apr 14, 2018 | 07:18 AM
medicmoose's Avatar
When I moved across Canada I ended up using a full trailer on the first leg and then used a dolly on the second leg. Both worked just fine but my preference would be to use the full trailer. Due to it being half apart at the time, getting it unloaded from the dolly was easier than the trailer.
In the end, both will work fine for you!
Old Apr 19, 2018 | 02:27 PM
MVP's Avatar
MVP
I'm towing my 'new to me' '83 home this weekend, most likely with a uhaul trailer instead of dolly. I'll try to get some photos to post during the process.
Old Apr 20, 2018 | 04:34 AM
95yoda's Avatar
awesome.
Old Apr 20, 2018 | 08:43 AM
dropzone's Avatar
Fossilized
dolley works fine until you lose your transfer case output bearings down the road or your truck drops into gear.
always pull the rear driveshaft if using a dolley
Old Apr 21, 2018 | 06:00 AM
medicmoose's Avatar
^^ Yup...easy to remove the driveshaft. Mine was being held together with bungy cords when I moved!
dntsdad
13
Mar 14, 2016 07:14 PM
stephen@yotatech
Apr 2, 2010 05:06 AM
northfacer581
Jan 8, 2010 05:01 PM
wild_ks
Jun 26, 2008 04:12 PM
4Hummer
13
Jun 21, 2007 08:35 PM
