brake lights fixed now turn signal out!
Old Mar 10, 2018 | 01:44 PM
pablo130's Avatar
Hi I have a 1991 Toyota pickup ext cab DLX 4WD V6. My drivers side rear brake light was out. Changed bulb did not fix. Ordered new tail light assembly as old one was corroded. Still did not fix brake light. Running light
works, turn signal works brake light not working. Chased wires and found a broken wire, fixed wire and brake lights work fine now! Only problem is now the turn signal does not work. This is on the drivers side rear. All other
turn signals work. Drivers rear does not work with hazards on either. When I activate left turn signal the indicator on dash blinks fast. Bulbs are good and tail light assembly is brand new. The turn signals worked fine before I fixed the brake light.
Any suggestions what I do next?
Old Mar 10, 2018 | 01:55 PM
pablo130's Avatar
update
I checked fuses under dash at left kick panel. All check good.
Old Mar 10, 2018 | 03:59 PM
scope103's Avatar
Originally Posted by pablo130
.... Chased wires and found a broken wire, fixed wire and brake lights work fine now! ...
Where? What color (including stripe) was the wire you "fixed"?
Old Mar 11, 2018 | 06:54 AM
pablo130's Avatar
The wire was broken at the rear behind the license plate. It was part of the wiring bundle coming from the passenger tail light across to the drivers side tail light. The wire is green with purple circles every few inches
with a white stripe. Once I spliced it back together the brake light started to work, but turn signal that was working before stopped working. I did leave power in the wire by keeping brake pedal pushed down, but I checked
fuses to see if any blew to a short but none were blown at the fuse panel driver side left kick panel. I did not check fuses under the hood.
Old Mar 14, 2018 | 01:30 PM
RAD4Runner's Avatar
..This is on the drivers side rear. All other
turn signals work. Drivers rear does not work with hazards on either. When I activate left turn signal the indicator on dash blinks fast. Bulbs are good and tail light assembly is brand new...?
Turn signal indicator blinking fast on driver side, all signals except rear driver's side working means:
1) Connection to rear driver's side bulb broken, OR
2) That bulb is open. how did you verify that the bulb is good?
Need to check wiring / connections to rear driver side bulb AND double-check that bulb. (Pls see signature)
Old Mar 15, 2018 | 07:36 AM
pablo130's Avatar
Okay so I checked the wires and found another wire broken. Repaired that wire and now turn signal works. So problem solved. Thanks for all the help!
Old Mar 15, 2018 | 09:48 AM
RAD4Runner's Avatar
Yes, like my signature says
Most welcome.
ss502
Jan 18, 2017 12:27 PM
travisamorgan
Apr 19, 2015 10:48 AM
Grendal1
Feb 26, 2015 09:25 PM
Yellowtruck
Oct 29, 2009 08:21 AM
