What do i need to check? Fuse, wireing harness, etc
Old Feb 28, 2018 | 04:38 AM
coolmatt3028's Avatar
Nephew hooked up the battery terminals wrong and now truck wont start. it'll crank but not fire. where do I start? we've replaced several fuses but still no luck.
Old Feb 28, 2018 | 06:37 AM
jakey poo's Avatar
What year, model, engine do you have? Which fuses specifically did you change?
Old Feb 28, 2018 | 08:32 AM
RAD4Runner's Avatar
See my signature.
Start with basics.
Originally Posted by coolmatt3028
.... it'll crank but not fire. where do I start? we've replaced several fuses but still no luck.
Got spark? Got fuel pressure? Hear, feel fuel pump run when you put IGN switch in "Start" position?
Did you verify that fuses were bad and that replacing them will fix the problem?
Got a multimeter?
Old Feb 28, 2018 | 02:59 PM
akwheeler's Avatar
Start by telling us what you are working on, like RAD4Runner said, then continue by getting a voltmeter and a test light. You probably have a blown fusible link, so check for power to your fuses with the key on and see what is getting power and what isn't.
atcfixer
30
Mar 15, 2024 06:26 AM
Lochsa
Apr 3, 2017 09:39 AM
red90toyota
Mar 28, 2017 06:03 PM
egesledder
All Other Toyota Swaps
120
Feb 22, 2017 06:14 AM
Rock Slide
30
Sep 12, 2008 07:45 AM
