Axle Breather Mod Alternative Question
Old Feb 14, 2018 | 10:34 AM
GodwinAustin's Avatar
Hey guys...I am well aware of the standard diff breather mod on our axles but was wondering if anyone has used one of these for the top part of the vent, or would have any commentary on how they would work for the purpose. Thanks.
Link to item on ebay: https://www.ebay.com/itm/5PCS-Bronze...72.m2749.l2649
Old Feb 14, 2018 | 10:35 AM
These seem to be the same you often see on aftermarket diff breather boxes, like this one:
https://www.ebay.com/itm/DIFF-BREATH...sAAOSwMl9acvS9
Old Feb 14, 2018 | 12:40 PM
akwheeler's Avatar
Check out Trial gear for a "creeper breather" they are far better at keeping water out of your diffs. especially if you locate them where they won't get torn up.
Old Feb 14, 2018 | 12:49 PM
ya I’m familiar with those ... but 20x the price
do you have bad experience with the brass fittings above or ?
Old Feb 14, 2018 | 04:11 PM
akwheeler's Avatar
I haven't used them, but I suspect if you get into deep mud or water you'll have plenty in your axles. they should be ok for a road rig though. I'm more into saving my gears and saving labor than saving $20
Old Feb 14, 2018 | 05:12 PM
muddpigg's Avatar
You can pull pull breathers from a nissan that had hose barb on them or purchase from dealership. On my "to-do" list, don't have research links handy to give year and model or part number but if I found it anyone can.
Old Feb 15, 2018 | 02:40 AM
wyoming9's Avatar
Red face
I would think mud would cover the brass filter then dry which would then block the vent .
Then your back to square one
If you never see mud or deep slush you will be fine
Being as I know quite a few Jackson`s all over the country if your up North and see liquid brine it will be in your differentials
Old Feb 15, 2018 | 09:30 AM
RAD4Runner's Avatar
Originally Posted by GodwinAustin
...for the top part of the vent..
Do you mean to replace the stock ones on top of the diffs OR to cap the top end of the breather extension
tubing that you will add like the one on your second post (https://www.yotatech.com/forums/f123...post52390547)?
IF former, no for reasons ^^^ . IF the latter, yes. Good ones to terminate the end above water/splash level.
Old Feb 15, 2018 | 03:32 PM
ya, I should clarify... these will NOT go on the axles but at the end of 1/4” silicone hose to inside the gas door and beneath the hood.
Old Feb 15, 2018 | 06:22 PM
RAD4Runner's Avatar
Then those are good.
Old Feb 15, 2018 | 06:39 PM
millball's Avatar
I just use small engine fuel filters at the top end of my extended breather hoses.
Old Feb 16, 2018 | 12:50 AM
Genera_lee's Avatar
yep thats pretty much exactly what those are for anyway. to protect outgassing without the incursion of other substances. we use ceramic versions of those as work to disperse gas in a chamber more evenly.
i'm planning to do the same thing.
in fact, LROR has replacement diff breather ports that thread directly in to the axle and are a hose barb.
link here
Old Feb 16, 2018 | 03:12 AM
arlindsay1992's Avatar
Just go to the junkyard and grab the nipple out of the intake manifold that goes to the brake booster. Same BSP thread as the axle breather, 12mm hex, and a nipple for 3/8" hose. All factory, and probably free if you buy anything else. Never seen a junkyard charge for nuts and bolts.
MillerPKA
25
Jul 19, 2007 03:05 AM
callmekurt
43
Feb 9, 2007 07:10 PM
rocket
47
Jan 24, 2007 05:10 AM
rimpainter.com
127
Feb 11, 2005 05:47 AM
Bob_98SR5
23
Apr 21, 2003 01:34 PM
