Axle Breather Mod Alternative Question
Hey guys...I am well aware of the standard diff breather mod on our axles but was wondering if anyone has used one of these for the top part of the vent, or would have any commentary on how they would work for the purpose. Thanks.
Link to item on ebay: https://www.ebay.com/itm/5PCS-Bronze...72.m2749.l2649
These seem to be the same you often see on aftermarket diff breather boxes, like this one:
https://www.ebay.com/itm/DIFF-BREATH...sAAOSwMl9acvS9
Check out Trial gear for a "creeper breather" they are far better at keeping water out of your diffs. especially if you locate them where they won't get torn up.
do you have bad experience with the brass fittings above or ?
I haven't used them, but I suspect if you get into deep mud or water you'll have plenty in your axles. they should be ok for a road rig though. I'm more into saving my gears and saving labor than saving $20
I would think mud would cover the brass filter then dry which would then block the vent .
Then your back to square one
If you never see mud or deep slush you will be fine
Being as I know quite a few Jackson`s all over the country if your up North and see liquid brine it will be in your differentials
Do you mean to replace the stock ones on top of the diffs OR to cap the top end of the breather extension
tubing that you will add like the one on your second post (https://www.yotatech.com/forums/f123...post52390547)?
IF former, no for reasons ^^^ . IF the latter, yes. Good ones to terminate the end above water/splash level.
yep thats pretty much exactly what those are for anyway. to protect outgassing without the incursion of other substances. we use ceramic versions of those as work to disperse gas in a chamber more evenly.
i'm planning to do the same thing.
in fact, LROR has replacement diff breather ports that thread directly in to the axle and are a hose barb.
link here
link here
Just go to the junkyard and grab the nipple out of the intake manifold that goes to the brake booster. Same BSP thread as the axle breather, 12mm hex, and a nipple for 3/8" hose. All factory, and probably free if you buy anything else. Never seen a junkyard charge for nuts and bolts.
MillerPKA
25
07-19-2007 03:05 AM
rocket
47
01-24-2007 05:10 AM
rimpainter.com
127
02-11-2005 05:47 AM
Bob_98SR5
23
04-21-2003 01:34 PM
