General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
95.5 Headlights wont dim, HELP
Old Oct 29, 2017 | 06:28 PM
edmondsonknives's Avatar
I posted this in another section I believe was the wrong section, I have a 1995.5 tacoma 4x4 ext cab. When I turn the lights on dim they both go out but the high beam indicator stays on on the dash. Turn signals work perfect, everything except when I go to dim the light I have no head lights. Ive checked the fuses, and the headlight relay looks to be in perfect working condition. High beams work excellent. before I drop 150 on a combination switch I figured Id ask the profesionals, Thanks for any help!!!!
Old Oct 29, 2017 | 06:37 PM
also has one new headlight on the driver side, forgot to mention
Old Oct 29, 2017 | 11:35 PM
wyoming9's Avatar
Red face
Time to break out the Meter .
How long has this been happening??
Some times the switch contacts corrode enough to not close the circuit
Wires break or corrode at the head light bulbs
Old Oct 30, 2017 | 10:16 AM
RAD4Runner's Avatar
Did you search sticky's?
This ^^^
Then check wire colors at headlight connectors if they match attached
Then take voltage checks according to this: https://www.yotatech.com/forums/f116.../#post52379293
Attached Thumbnails 95.5 Headlights wont dim, HELP-screen-shot-2017-10-30-11.10.24-am.png
