fuel injector lube
Old Sep 30, 2017 | 09:23 AM
maninnepa's Avatar
5 Year Member
fuel injector lube
1989 3vze
Old Sep 30, 2017 | 09:33 AM
scope103's Avatar
Gasoline
http://web.archive.org/web/20131107190313/http://personal.utulsa.edu:80/~nathan-buchanan/93fsm/engine/90injector.pdf
https://www.youtube.com/watch?v=XPY5P0TaC4k
Old Sep 30, 2017 | 10:33 AM
maninnepa's Avatar
5 Year Member
scope103...thanks for quick reply. Another question, I got refurbished denso fuel injectors and the small top O-rings fit loose. Are they supposed to be or did they put the wrong size on??
Old Sep 30, 2017 | 12:13 PM
scope103's Avatar
You don't care how tight the o-ring is on the injector, you need it to be tight inside the bore of the rail. So if it can be fit into the bore without wrinkling, it's fine.
But when I replaced my o-rings, they fit pretty nicely to the injector. Yours just might be "too" loose.
Old Sep 30, 2017 | 03:41 PM
maninnepa's Avatar
5 Year Member
well, I found 6 toyota OEM ones for 13 bucks....gonna get them and see if they fit tighter or the same. thanks again.
Old Oct 13, 2017 | 04:49 AM
maninnepa's Avatar
5 Year Member
So I got the OEM O-rings and they did fit snugger on the injectors AND the O-rings were not as hard as the ones on the refurbished injectors.My guess is the refurbisher was not about to spend 2 bucks for each O-ring when he could find something close for 10 cents each!....anyway, the install went good with no leaks.
Old Oct 13, 2017 | 07:12 AM
scope103's Avatar
At a dealer? Online? You did the work; someone on this forum might really benefit if you gave where you got them and the part numbers you used.
Old Oct 13, 2017 | 07:31 AM
maninnepa's Avatar
5 Year Member
This is where I got them...
6 of Toyota 90301-07001, Fuel Injector O-Ring 6 of Toyota 90301-07001, Fuel Injector O-Ring
Sold by:
Genuine Parts Planet Genuine Parts Planet
$2.33
I got them on Amazon, but I just clicked "buy them again" and it says currently unavailable....other vendors have them, but not at that price.
dukestr
20
Jan 4, 2003 09:40 PM
williemon
Dec 6, 2002 10:20 AM
Toddski
Oct 2, 2002 07:00 AM
