1983 pickup exhaust
1983 pickup exhaust
Hey guys, I need to replace the exhaust on my 83 22R pickup so I wanna know what size of pipe would be good for it. I don't wanna use the same setup it has now though which is stock
Engnbldr has lots of experience racing 22r/re engines and they don't see a benefit in pipes larger than 2 1/4". Not saying 2 1/2" is a bad choice, but it doesn't seem to be the consensus, either.
You can also check out a chart used to determine pipe diameter on custom setups and see that 2.5" pipe is recommended for 3.3-4.5 litre engines that make between 200-250 horsepower!
It's your truck so do what you want.
You wouldn't be the first person to build a monster exhaust onto a tiny little engine with small power output. What'll likely happen is you end up with less power than you started out with.
I've got a pretty hot 22R and I'm running 2 1/4" exhaust. That would be my recommendation.
Like stated above though, it's your truck, do as you please. Just please don't run a stack up through the bed. It just looks stupid.
All I'm really looking for is something that'll sound nice going down the road and will give me better performance than what I have now
Quiet muffler
newb here, forgive my ignorance. Can someone recommend a quiet muffler for a 20r? I'm old, what can I say! Btw, I think YT is paradise found. Thanks.
Last edited by Waterfreek; Aug 8, 2017 at 05:37 PM. Reason: No response, newb mistake
I think I may give the cherry bomb a whirl. The muffler on it at this time has resonance/ harmonics that are hard on my ears. Just can’t get used to it. Thanks for your help.
I just finished the exhaust on my 82 bringing it from the muffler and exiting out under the rear bumper.
my muffler was 1 7/8 outlet so that's what I used. That is plenty for this application.
