winch solenoid relocated, snapped winch cable end
Old Apr 4, 2004 | 10:41 AM
Talking winch solenoid relocated w/pic, snapped winch cable end
I just relocated the winch solenoid pack into the engine compartment. Its placed about where Schaefer has his but is just snuggled in btwn some other components not bolted down.
I have 2 questions I hope someone can answer.
1: Is it okay to have metal or wires touching the metal a/c lines?
2: Is the small red w/ black cover wire running from the solenoid to winch just a ground? I spliced it w/ copper wire and no cover but taped the splices good is the cover important?
The other thing is I already broke the tag end of my winch cable while letting it out under load . 80' is shorter than I figured. I guess Ill HAVE to buy a synthetic line now I mean I have no other choice right.
Attached Thumbnails winch solenoid relocated, snapped winch cable end-solenoid_0021.jpg
Old Apr 4, 2004 | 11:33 AM
RTdawgs's Avatar
answer to #2: not sure if its a ground, but the cover was probably there for a reason, i would make sure its covered.
the terminal end of my rope has come off before. i just crimped on a new terminal and re-mounted it, its as good as new.
you should call and talk to a Warn representative, they are very friendly and very helpful.
Old Apr 4, 2004 | 11:34 AM
I have finally succeded in posting a pic on my own. But Im not sure how I did it
Old Apr 4, 2004 | 11:36 AM
Thanks Ryan, I hope I ca get a cover that will slip around it and not have to rewire again.
jasonty
41
Dec 23, 2018 01:00 PM
CanRunner
Jul 20, 2015 01:29 PM
jgwerth
Jul 16, 2015 03:23 PM
mengquis
Jul 13, 2015 10:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
