Looking for a cruise control wiring diagram for a 3RZ 4runner
Im installing OEM cruise control into a 1998 3RZ 4runner with manual transmission. The truck didn't come with one from the factory. It's not pre-wired for cruise control either.
I got ALL the parts needed from a junk yard (not easy, since 3RZ and 5VZ cruise components are COMPLETELY different, and most 3RZ trucks didn't have cruise), but I need the wiring diagram to put it all together. There is about 2 dozen wires going into the cruise control ECU! Going to be a fun project...
Either way, if anyone has the wiring diagram, please let me know. I have one for 2000-2002 trucks, but its completely different because 2000 trucks never came with either 3RZ or manual tranny.
One 1998 3RZ Cruise Control EWD from my personal collection:
https://drive.google.com/open?id=0B9...kZEeXFmaTFibUU
Where they differ, wires are marked A/T or M/T.
The diagram you posted seems to be specific to 5VZ. The 3RZ wiring is significantly different. On 3RZ, the cruise actuator has 7 wires going to it, while the 5VZ actuator only has 4.
Would you happen to have the 3rz diagram by any chance?
https://drive.google.com/file/d/0B9I...ew?usp=sharing
Thanks again, but that seems to be the wrong diagram. Is it possible that its for Tacoma?
As I've said earlier, the 4runner 3RZ cruise actuator connector has 7 wires. The actuator on the 3RZ diagram that you posted is the same one as the 5VZ and has 4 wires.
No, that is the 1998 3RZ 4Runner CC EWD from Toyota TIS as far as I know. I got it from another forum member who has a '98. '99 also has 4 wires. '97 has the seven wires so here is that one:
The Toyota EPC that I have shows the 7-wire actuator being used up to 08/1997 production date. These trucks would be sold as 1998 models. This is also confirmed by the fact that I pulled this actuator from a 1998 truck.
Perhaps early "1998" trucks used the 7 wire actuator, and late 1998 ones used the 4 wire.
Either way, I greatly appreciate your help!
You, sir, are a lifesaver! That's the diagram I need!
Either way, you're welcome.
Since you have both schematics for what it is worth the hard copy EWD for the 98 4runner shows a 4 pin connector for the cruise control actuator and it is black and this is for the 3rz
I don`t have cruise control in any of my 4x4 vehicles I never drive where it might be used
