22re tap the gas to start
Yet another "I need to crank the engine a couple times and tap the gas to start it" thread. It's not the end of the world, but I like my engine to run properly. (and the looks at wo
Symptoms-
Suspect things compiled from research-
This seems to be a problem many of us have, and all the troubleshooting threads I see on it are scattered in different directions.
Symptoms-
- Not really temperature dependent, but obviously when it's freaking cold in the morning it's harder to start.
- Letting the key sit in start for a few seconds, THEN pushing the clutch in seems to help, indicating fuel pressure, but it isn't always sure-fire (pun intended) so that could be my imagination.
- What definitely does help is having my foot tapping the gas as I let off the key.
- After releasing the key, I need to feather the gas for a couple seconds to keep it from dying
- The other thing I notice that may play in: every afternoon after work it's a hard start, then the only light on my way home is a mile or so down the road (engine neither hot, or cold). At that light, I usually (maybe always) have the issue where pressing the brake causes the engine to rev up and down, as though the idle adjust is set too high. (i have a new idle adjust screw, and (think) it is set properly). This issue might be outside the scope of this thread, but could relate to the IAV or something.
- idle air valve/aux air valve, which is it called?
- fuel pump
- fuel pump check valve
- Grounding of sensors somewhere
- bad csi timer sensor
- bad temp sensor
- my EGR system was removed by a PO
- cold start injector
- could have a messed up vacuum hose somewhere
- The starter relay mod
- injectors need cleaned
- throttle body needs cleaned
- fuel filter
- fuel filter when I got the truck August 2016
- new idle adjust screw from LCE and set it to 600-700 rpm with the engine hot
- battery is fine
- o2 sensor (can't think of any reason that's relevant here, posting it anyway tho)
- I just checked and iIt looks like I have that relay built into my 86 that rad4runner champions here https://www.yotatech.com/forums/f199...l#post52323181. have not done the relay mod yet.
- clean sensor grounds
- relay bypass mod
- fuel pump hotwire troubleshooting jumper
Please see my comments in lime on things that I've had experience with...
- Not really temperature dependent, but obviously when it's freaking cold in the morning it's harder to start...
- bad csi timer sensor, cold start injector.
- bad temp sensor...
Although not clearly temp-dependent... wrong temp signal to the ECU may affect idle. After 30 years, I think a thorough cleaning of temp senders, their mountings, and wiring is a good idea to help eliminate doubts on them. I recently did mine and it fixed my hard cold starts and rough cold idle.
- clean sensor grounds,Grounding of sensors somewhere... [rad4runner: CSI timer switch relies on mounting thread on block for grounding.]
- The starter relay mod. [rad4runner: only helps with cranking but whether the problem occurs or not, it definitely needs to be done because the starter relay is wired wrong from the factory]
- relay bypass mod [rad4runner: same as starter relay fix?]
- fuel pump hotwire troubleshooting jumper [rad4runner: I just did timing and RPM check and a nicely done jumper with proper spade connectors, 1/4-inch I think, would have helped make my job quicker and safer]
- fuel pump stuff [rad4runner: may I suggest a fuel pressure gage piggybacked on CSI? Inexpensive mod that helps eliminate doubt on fuel system- write-up is on my thread. I'd like to eventually replace with electrical sender and gauge on dash]
I think, of all the things in the world, after cleaning temp sensors and replacing a starter and idle screw gasket and messing with idle and checking every vacuum line and contemplating sending my injectors out for cleaning and
for a few months... cleaning my battery terminals fixed this
Simple things first always works
