Intake: Engine Dies When Air Cleaner Box is Opened
Hi folks,
#rad4runner had been running very well, especially after I fixed my hard cold starts with rough idle upon starting.
Earlier, when I was having the hard cold start-rough idle issue, undoing the latches on the air-box and lifting the AFM/Lid up did not do anything
However, recently, when I do the same, the engine dies.
A couple of weeks ago, I went off-roading with a group in the desert. I cleaned the air filter as well as I could.
I am not familiar with ECU logic, but I'm suspecting that the ECU had "learned" to compensate for the loaded air filter so when I lift the air-box lid to let it breathe better, the fuel-air mixture all of a sudden gets too thin? I will pick up a new air filter tomorrow and install it.
Do you know if ECU would automatically adjust to the new condition? OR do I need to disconnect battery to let it re-learn operating conditions?
TIA!
TIA!
That is strange
It should in theory not happen because opening the cover is up stream of the AFM switch now if it was down stream like in the air intake tube I can see it shutting off the engine
I would hope removing the cover would not be effecting the plug connecting the AFM
You could remove the filter and it should not stall the engine
This ECU is not that advanced just put your new element in and call it good.
Although I am such a Klutz around any thing electrical I remove the battery when I check the oil just to be safe
Been so long since i drove a 2.4 I need to go look at one in the shop
After looking I have to think doing something to the afm connection or wires
The other would be unmetered Air from either a crack or a loose clamp
Wally and Arlindsay Nailed it.
Thanks, Guys!
Wally, Wyoming and Arlindsay nailed it.
Another disadvantage of having the intake duct cross over the radiator/hose.
It's not bad when in normal position, I could not find replacement at pick a part, and the 86 will get her kicks on Route 66 tomorrow, so I sealed with two layers of 10-mil pipe cover tape.
Will order replacement online and have it shipped to my brod's in TX.
If anyone is near the I-40 /Rte66 between So Cal and Amarillo, pls let me know if we can have a little coffee.
Would also appreciate recommended mechs shop along the way, in case I'd need it.
I'm not in Albuquerque any more, so I can't have coffee with you. But I can offer up some recommendations on food stops along the old 66 corridor in NM:
- The 66 Pit Stop - Home of the Laguna Burger - West of Albuquerque, on a section of old 66 with a cool bridge.
- El Charritos Mexican Restaurant - 47th and Central in Albuquerque. Great New Mexican food. Probably the best Carne Adovada I've had.
- Monte Carlo Liquors and Steak House - Central just east of Atrisco, Albuquerque. Burgers and fresh cut fries - yum. Cool old place. A locals' hangout.
- Java Joe's - 906 Park Ave SW, Albuquerque, just off Central. Coffee and good baked goods. It's on the Breaking Bad list of locations.
- Del's Restaurant & Gifts - On the old 66 strip in Tucumcari. Can't go wrong with a breakfast or lunch at Del's.
DORMAN 696707 {#2223135011}
http://www.rockauto.com/en/moreinfo....2158&jsn=10426
Thanks Arlindsay, and Thanks Wally for the tip.
Awesome!
Thanks a lot, Sir!
Thanks a lot, Sir!
Awesome! Could it be this one? Found it on Rockauto.
wally
Unfortunately, I passed Albuquerque late and I wanted to tackle the dirt section between Santa Rosa and Cuervo, then between San Jon and Glenrio, NM, so I just drove through then camped at travel center in Santa Rosa.
Some pics/vids from trip here
the intake hose costs almost $20 more, but it doesn't have that radical bend in it, and the cold start system is much better.
Also having my transmission worked on in Dallas for what sounds like intake shaft bearing issue, TX so budget and time would be tight right now. Yes, the Yota made it all the way to Dallas and I could have driven her all the way to Houston, then Galveston (for a coast-to coast road trip), but I wanted to play it safe so I needed to leave her in the shop.
We originally took her to Plano Transmission, shop with great reviews on Yelp, but shop is full and I wanna get her done within next week for the drive back to So Cal. Shop owner sent us to another shop that he contracts manual transmission out to...
On our 45-minute drive down to south Dalllas, tranny noise did not manifest it self... pretty intermittent, and I'm still getting my 19-MPG's.
Got myself a zippy 4-banger loaner
LOL!. Imagine my 13-foot kayak on top of it?
Thanks, OSV. Yes, I'll look into that.
All,
Any experience with batt-intake swap with regards to smog regs in California?
All,
I would love to say they wouldn't notice but they will, they know All.
The intake pipe across the engine bay against the radiator is the replacement design for the preheat chambers they patented for the early models. I want to say 18r had them. So I'll be interested in that answer also.
NewOldRunner
Feb 26, 2010 07:10 PM
Denk
Mar 26, 2006 12:43 PM
