Comment on Silverstars
I took my truck up to our family farm this weekend and I can say without a doubt they do shine bright. It has been kinda hard to tell if they were any different in the city, I like the whiter light better regardless, but the brights on in the woods were lighting up everything. Anyone considering them, I'd recommend them.
Originally Posted by 4x4Fink
My only beef is the weakness of them in really dark conditions (not being able to use high beams) and in rainy/snowy conditions...oh wait, I've got fog lights now...nevermind!
Fink
Fink
Soon as my darn rack gets here. What gives yoda-g2?
Silverstars are liscenced by Osram Co. to Sylvania. The Sylvania bulbs are inferior to the Osram bulbs in every way, shape, and form, including construction quality. Build variences are so high w/ the Sylvania bulbs, that you get 2 months to 2 years. My first set lasted 6 months. Second set, 3 months... the current set has been in for a year, but they're Osram bulbs that I ordered, not Sylvania bulbs from my local parts house. The Osram's also look MUCH better than the Sylvania's. And NO, I'm not touching the bulbs, my housings are clean, and I wear gloves and wipe down the bulbs w/ denatured alcohol if they get contaminated prior to install. It's a crap shoot. Personally, I'm more impressed (for the $$$ ) with my John Deere HIR bulbs. You guys should check em' out. $30 or so from your local John Deere dealer...
On the other hand, Sylvanias are way better in my opinion. They're whiter, brighter and last longer. I'm on the original set after 1.5 years, and that's considering the fact I have DRL all the time.
-- Andrey
HIR is a new technology that uses coatings to reflect and absorb the infrared heat given off by the bulb to effectively heat the filament up more, thus, improving the Kelvin reading, thereby making the light brighter. They work, and the $30 or so spent @ John Deere is better than the $100 or so that IPF wants for the same technology.
Originally Posted by Godzilla
To an earlier comment by 4x4Fink. Is there no highbeam with those lights?
Fink
I see with your Cruiser you running the HIR's but are you using them in the runner?
Check out this website:
http://www.suvlights.com/
Osram +50 is a nice upgrade from stock - The bulbs last approximately 10 to 14 months depending on how much night driving you do. The low beam will probably burn out first - that's been my experience anyway.
O.K. I'm interested in the HIR's or the Silverstars, my question is do they make corners bulbs to match.
I have clear corner lenses and the color difference from the corners to the headlights drives me nuts.
