22re and v6 gear ratio and more !
Old Sep 30, 2016 | 05:25 AM
Thord's Avatar
Hi guy's i would like to know at wich RPM the 22re with a manual 5 speed transmission will turn at 100km/h / 60mph on original size tires , oem diff etc" **EDIT: with a 4x4 transfercase**
Also , at wich RPM the V6 with a 5 speed manual transmission would turn at 100km/h / 60mph with original everything too.
Does the v6 transmission bellhousing be swapped over with a 22re bellhousing ?
I'm currently finishing my TDI ALH swap into my 1992 4runner , originally 4x4 22re engine 5 speed manual.
The problem is , to fit the engine in , i had to move the whole drivetrain forward 4 inches , ( i installed a v6 transmission crossmember to get everything forward ) , wich now make my shifter hit the dash , my driveshaft to be spaced.
Currently the truck is running fine , but it's an old beated up , rough body that i bough for a handful of peanuts , i will eventually buy an other body in much more descent form and swap over my engine.
The thing is i would like to buy 'the right truck from the start' if i know i can buy a v6 , remove the engine , swap the bellhousing and VOILA , no need to shift everything forward , no driveshaft to space and no more shifter bending thing to do , i would be soo happy !
Sorry for the long and somehow boring first long post.
Thanks in advance for your help , and please , forgive me about my not soo perfect english !
Thanks , Jordan.
Old Sep 30, 2016 | 03:30 PM
cbr600rx7's Avatar
http://www.grimmjeeper.com/gears.html
this will get you started.
Old Oct 1, 2016 | 07:32 AM
Thord's Avatar
I know the 22re is mated to a w56 transmission , but what about the 3vz , what is it's transmission code ?
Old Oct 1, 2016 | 08:23 AM
cbr600rx7's Avatar
Search or google.
Old Oct 1, 2016 | 09:28 AM
millball's Avatar
3vz-e 5 speed manual tranny code on my '95 Runner is: R150F
Old Oct 1, 2016 | 12:56 PM
muddpigg's Avatar
The Google-fu with this one needs more training. Think it's even in wiki, gears to rpm is on marlin's site. Eric's site has the lift and spin method of figuring gear ratio.
4Nmissile
Apr 14, 2013 03:20 PM
golden88
Jan 21, 2013 07:27 PM
3cRider
Jan 3, 2011 08:03 AM
alankenji_84
Mar 26, 2008 10:53 AM
