Rear differential pinion seal?
Old May 22, 2016 | 01:46 PM
d-wood's Avatar
It's a 1993 toy p/u 22re 4x4
When I went to take off the nut to get to pinion the seal, it was very easy to take off. I read about how your suppose to turn it back to where it was so you do t mess anything up.
I feel like the po didn't tighten it correctly or is it suppose to be that loose? Mines the 8"
G292
Old May 22, 2016 | 04:18 PM
millball's Avatar
I have tightened many up to 120,130, even 140 foot pounds without changing the pinion bearing preload any.
If your 3rd member is sound, you should not worry, just torque her down. Anything over 90fp should suffice. As I recall thats the torque spec on tranny/transfer case yokes.
Old May 22, 2016 | 04:47 PM
d-wood's Avatar
Thanks millball!!!
Old May 24, 2016 | 12:35 PM
Billythekid's Avatar
The pinion nut should also be staked so that it doesn't loosen up.
Old May 26, 2016 | 06:39 PM
d-wood's Avatar
I probably should of got a new nut but I just staked it in a different spot cause the other spot was crappy where it was staked before.
I haven't any leaks and it doing fine so far.
CharlesNorris
May 10, 2024 07:45 AM
admiralnahohkta
Mar 1, 2020 01:44 PM
byron4
Apr 23, 2016 05:23 PM
Rsloop90
Apr 5, 2016 02:02 PM
firemanyota89
Mar 27, 2016 11:51 AM
